rford426
Resident 5.0 H8R
Good Luck Matt!!
could have something to do with whatever you have changed lately on the car.
My bogarts have the 275/60/15 drag radials on them... maybe I should try them at the strip lol
last thing i did was add cams and delete plates.
How hot was it out there Matt? Full slicks will help as mentioned. It is nice to run a new set of tires to get some good traction.
I figured as much. When it is hot , I find that not heating the tires up as much seems to help the hook up. Your going full slicks so it really does not matter. Your going to see a big improvement now with the new tires. I could not hook up, untill I got the Eibach Drag launch kit.Yea I use the air bag.LOL. I also went to M&H racemasters ,just recently. I think you are fighting the heat again,maybe a cool day will come into play for you. Best of luck next run!We have had some hot weather latley... 20-25 degree's C
You might want to cut your rubber bumper(on the axle) down to the first rib. It will help a lot also. What happens is you hit down really hard on the rubber and it bucks the car,this causing you to blow off the tires. Look under there and see if you are hitting the metal above. My bet is you are. This is what I had to do to quit blowing off my tires. You are almost there,I could not get any better than a 11.930 untill I did that. Amazing how traction helps.Thanks man, I just want to be able to dump the clutch above 6000 rpms again... right now im pussying it with 5000 rpm launchs blowing the tires off xD
28's should look bad ass aswell.
I tried 8,9,10 psi on these current et streets this weekend and all came up with crappy sixty foots.
lol
