Anthony05GT
BruceH is right. Either that or drop the crossmember and take a long extension with a ratchet and go from the rear of the transmission all the way along the top to the bolts while the trans is hanging down a bit.
You're in for a fight with this if you haven't done it before. I've had these transmissions in and out many times and have my own way of doing it. On cars with stock motor mounts you need to pry the rear of the engine down for easy in/out of the transmission. That's easier if you have a buddy doing the prying or pry it and block it somehow. On cars with poly motor mounts it's tougher. Getting it out is easy, but getting it in requires the right moves. I have to have the tail piece of the transmission down low compared to the bell housing until the input shaft is through the diaphragm, then raise the tail piece and slide it in.
On my car with the twin screw blower keeping the engine from being tilted back I took a big dead blow hammer and pounded the trans tunnel after the transmission was out in the areas that were scratched by the bell housing while it was being removed. Now, when I put it back in it's a cinch. It didn't take much sheet metal movement to really improve installation.
