Status
Not open for further replies.
Fabman
Children Of The Corn
Pleasanton, Ca.
Engine is .010 over stroker (300ci) JDM stroker (302 cuin)
10.3:1 compression 10.5-1 compression
FRPP Stage 2 heads stock heads
Comp 127300 cams Comp 127300 cams
Edelbrock E-force 16psi Kenne Bell 2.6@17psi
4R70W trans TCI street fighter 5r55s
4.10 gears 373 gears
M&H 325/50/15 racemasters Hoosier 325/50/15
Kooks longtubes/offroad X BBK shorties/catted X
dysan
Dis-Member
Williamstown, N.J.
E85, leaving off the trans brake and flowing more from the heads I'm guessing is the difference. I don't have to start pulling timing until 170IAT's with the E85 so it was peaking around 23 degrees of timing. 1 3/4" long tubes and no cats will also be helping me quite a bit.
The 60' makes a huge difference as well. The general rule of thumb is you get 1.5-2x more based on how good your 60' is so if I'm 1 tenth faster in my 60' I'll be 1.5-2 tenths quicker ET in the 1/4.
What will really get you is that I could have left harder but I forgot to turn up my 2-step. That was only leaving at 2800 rpms and I'm guessing I could have gone up to 3400rpms or so which may have gotten me a 1.42 or 1.41 60'
EDIT: The biggest indicator though is the mph...your car is definitely down on power because if you don't spin you really can't fool the mph much.
dysan
Dis-Member
Williamstown, N.J.
No idea on power because my car has not been on a dyno. Weight with me in it for that run was probably around 3900lbs since I weighed it the day before with a full tank of gas and 100lbs added and it was 4025lbs.
If I was to guess I suspect at the crank is upper 700 range based on my friends drag race calculator.
Fabman
Pleasanton, Ca.
That's awesome!
JimIII@JDM
Mike Dellisanti 2008 Mustang GT
9.08 @ 149 (MPH reflects lifting off throttle from a bracket race, car's best MPH is 152.7, Slip provided below)
MPH time slip:
- Cubic inch displacement (CID) of engine JDM 302E
- Type of transmission (by model number) Rossler Turbo 400
- Size and Manufacturer of power adder, or N/A Roush 2.3L TVS
- Pounds of Boost, of N2O shot (or both if applicable) 19 psi
- Rear Gear ratio 4.30
- Make and type of tire Hoosier 9.0x30x15 Radial C06
2FST-4U
louisiana
2013 mustang gt 5.0 Paxton 2200,ford racing aluminator 9.5 comp,pypes long tube headers,facotry 6r80 with a precision industries 3200 converter, 3.15 gears, 14psi, 275/60/15 mickey Thompson pros.
GT.350-R
3PEDLS
Portland IN.
Stock 281 inches
Stock cams
Stock clutch
Stock trans - 3650
4:88 gears
Running on Welds with M/T 275/60/15 DRs
11.96 @ 115.98
Zodiac
Cary, NC
For your time to be added to the Official ET Ranking List, you will need to post the following:
1)
2) The following vehicle information:
- Cubic inch displacement (CID) of engine: Stock 302
- Type of transmission (by model number): 6R80
- Size and Manufacturer of power adder, or N/A: N/A
- Pounds of Boost, of N2O shot (or both if applicable):N/A
- Rear Gear ratio: stock 3.15
- Make and type of tire: Stock Goodyear Eagle F1 Supercar
Video of run:
http://api.viglink.com/api/click?fo....0 - YouTube&jsonp=vglnk_jsonp_13692612675068
Hopefully looks like I filled everything out right.
2011BaseGT
What that I'm the fastest bone stock Boss in the country on radials. 12.17 I relish it!
mr. anderson
Moore, OK
still working the kinks out, here's a test and tune session only got 2 runs in.
1) Best 1/4 mi (5/11/13):
11.430 @ 124.13,
60' = 1.95
330 = 5.029
1/8 = 7.500@ 96.68MPH
1000= 9.657
1/4 = [email protected]
2011 Mustang GT
2) - Cubic inch displacement (CID) of engine: 302 4V
- Type of transmission MT-82
- Size and Manufacturer of power adder, or N/A: Kenne Bell 2.8LC
- Pounds of Boost: 12 pounds
- Rear Gear ratio: stock 3.73's
- Make and type of tire : MT ET Drag radial 295/55 15's
2012Coyote
Fuggit.
Mansfield, OH
^I would kill to have a 1.68 60'
Currently 1.79 is the best for me on my 295/50R16 MT ET Street II's
11.818 @ 120.02
Stock sealed 302 4V
Stock Air Box, Naturally Aspirated
Stock MT82 on stock clutch
Stock rear end with 3.73's
This was that night:
05stroker
Never enough power guy!
Bullard Tx.
10.04 at 137 1/4
6.46 at 108 1/8
1.48 60 ft
On 20" Nitto NT05R DRs
Put them all in the same pass and it would have been one hell of a day at the track!
Status
