Alll of you running big boost 22+ pounds.
I run the ngk gapped at.28. Should the gaps be closed up more .
Alll of you running big boost 22+ pounds what are you galling ou plugs at . I was having belts lip issues but the car still falls on its face up top
I gap at .032.
Are you running 2 step colder plugs? At 22+ psi you might need to drop down a heat range.
I presume you mean .028
I'm at 20-21 and run .028 as per Jon Lunds recommendation.
You could boost 2+ cars with that much. Nice!
