Starts - Runs - Dies poss fuel issue **FIXED**
So I woke up this morning ready to pull apart my axle right.......LOL
I did a thread search here and on google, I have found nothing close enough or conclusive to my issue.
I think I know the answer to my issue but I want to run it past you guys before draining $48 of gas out of my tank and buying ANOTHER fuel filter.
So I went to do a few things today, first thing I went and got 12 gallons of gas.
went to work to talk to my boss. the distance to work is about enough to run the gas out of the line.
I leave work, it stalls suddenly. I pop the hood to see if anything was obvious, nothing was, a minute later it started back up.
I got to an intersection about 1/4 mile down the road. It died again. I called a tow truck. $80 later I am home.
pull the fuel filter, blow through it, its clogged. Usually I cannot get any air through a clogged fuel filter but I felt there was a ton of restriction.
I have a spare lying around. When I first got my car I changed the fuel filter. When I tested the old filter it flowed like new so I kept it. I installed that.
Car died after 6 min of idling. I pulled filter back out, tested it, and found it was just as restrictive as the filter I had taken off.
Walked to gas station to tell them about it. They said they have sold 10k gallons of gas today and everything is fine. I walk to parts store and get another filter. $20
Come home, purge about a gallon out of the fuel system through the fuel line. Install new filter and test. Idled for about 10 min and died again.
new filter is now quite clogged, but seems operable.
I go to do my first round of internet searching.
I pop the hood and check for any loose electrical connections and reboot my tune.
install filter again. Idol car for 20 minutes. It struggles a lot but seems to smooth out eventually. I do laps around my neighborhood, all is fine. I go down the street to gas station to drop of the gallon of gas that I purged. Talk to those guys. Take off to do everything I had not started yet today at now 5pm.
I get another 100 feet, across the light, I feel a loss of power, pull off just in time to get my car close to a parking spot before it dies.
wait about 10 minutes, car starts, I drive it home.
I think I will need to buy ANOTHER fuel filter and completely purge the tank. Something I just don't want to do right now.
I mean, I woke up thinking about installing my diff clutches that have been sitting on the shelf since January LOL.
any ideas on this? does it look like I have missed anything?
I ask because in some other forums and threads people are saying this could be a sign of the alternator and battery going bad. sounds outrageous, but I hope to have this fixed replacing as few functional parts as possible.
thanks
thanks
