weather man
Persistence Is A Bitch
Great job!
Great job!
Sweet. Trade you compressors??
I figured out the belt issue, it was a bad idler pulley, the lower groved pulley on the DS. It looked fine but when I swapped it out the problem went away!
Now back to breaking in the new motor!
Congrats on getting rid of the CEL. I'm also using Driven Oil but the FR20 which is designed for the Ford Mod motors and the Coyote.
That's what I needed, they are the same as the ones I have now from the kit I whipped up. They are advertised as a little larger off set as are mine. That tells me the brackets will work will what I have now. Thanks!Also, for Billy, not sure if you still want this info or not but here's one of the back rotors, looks like its about 2.25" tall. I had to pull it off to fix an oil leak at the PS c-clip elim.
Looks like you are on track now. Maybe you can bring it by the Dealership for me to see in person one day. Autonation Ford of Ft Lauderdale
