The Official LostSoul Thread!!
lostsoul
2014 vett or 2015 stang..
Gay Area
LOL! You kill me! Have you really lost 2 crank bolts?
And 70k back at ya!
haha.. someone fucking shoot me now!!! SD.. do it.. just do it!! ahhhhhhhhhhhhh
when the bolt came lose the first time.. PROcharger told me I COULD reuse the same bolt.. so I just though forcefed didnt put locktite on or didnt torque it right(as they fucked up on other things).. I did everything right and worked for 2-3 weeks till the idle started to act up (after hitting Stanly in revirse:dead:).. I took it home and called procharger again.. THIS time they tell me its a streatch bolt and needs to be replaced.. so I order it.. got it and took 5 F'ing hours to install because there is a 1 inch clearence between the damn fan shroud and pully and its a neightmare to get to. finally got it on.. next day tried it and noticed the damn thing wobbling as if the procharger pully is warped. So I gave up and took it into the shop.. $170 for pully+ 14 for bolt+ almost $300 in labor!!! AHHHHHH.. The first time it came lose the pully was fine.. but second time was a no go.. too much damage. I was mad at forcefed at first.. but I dont know if they "should" have known to replace the bolt when rebuilding the engine. (Btw: I used the rtv)
I just cant believe the shit luck I have :wtf:
should have listen to Don.......and SD.... and Hawg...ect :kill:
05stroker
Never enough power guy!
Bullard Tx.
And the result would have been?
05GT281
ole' legend lime
Ft. Laud FL
How's the fuel pressure ?? You could be having a lean pop. I have my doubts on the head gasket. When your motor was done did they mill the heads or the block at all ?? Let us know what's up with the plugs.
+1 with Don on additional parts. Resolve this problem first and minimize the abuse until it's fixed or you might end up starting over again
ZmanM3
The Evil One
Jackson, NJ
Guy, keep reading, he has other problems now.
Charlie Sheen
Armed and Hammered
Infernum ubi sum
Have you been into my Morphine?
lostsoul
Gay Area
Its time for the rebirth! Dawn of a new day.. sort of.. The rebuild process has taken another step today.
As a little flashback you might remember this happening in Jan.
After a few months of male crying I talked myslef into getting another stang...
While the old stang is guarded by "trunk puppy" security system..
For the last 2 months we have been working to move the modded parts from the old car to the new one. As posted in the chit chat thread the rear end has been taken off along with most of the suspension.
Today we took out the procharger and engine..
That should answer the questions if the tranny and engine can come out at the same time. I have a higher floor plan though
Last week I remembered to check my stock h-pipe and there I saw one of the cats thrashed( the one that I had the exhaust leak issues). My plan now is to hollow out the rest and put the stock mufflers back on to help quite the noise. has anyone tried this? I know the engine light will come on but not sure if I will run lean even though its on a stock stang. Later I will install the forged engine and SC, but just wanted to see if I can run with it.
Other then that I will make a post in the parts sections.. if anyone needs an oem part let me know.
ZmanM3
The Evil One
Jackson, NJ
Wow Ted, you've been busy. Or should I say Brent has been busy and you've been drinking beer? Haha, I am sure your happy to have some progress.
