tnsaleen's Official Build Thread: 700rwhp or Bust!
tnsaleen
Nashville, TN
So I ended up getting a turbonetics hurricane Silvia turbo, 7268 .81 a/r, and got brave enough to build my own hotside. I very much dislike the under the a - arm pipes, so I got the idea from one eyed willy.
With the prothane bullet motor mounts spaced 5/16", new power steering lines on the rack, and oil filter relocation kit, this will give me the clearance I need to run a 3 inch up pipe all the way from the y collector for the 2.5" pipes coming off the manifolds.
I hope to have the hotside done by the end of next week, so we will see what happens!
tnsaleen
Nashville, TN
I would really like to keep my sway bar on for handling. However with the relocation brackets I made, it drops it low enough to be too close to comfort to the inner tie rod. I was thinking adjustable end links, but don't know if they actually get shorter than factory links. Another option could be a bump steer kit, or factory links moved to the other hole on the strut, but I think the geometry of it would adversely effect everything.
Any input or advise?
Sent from my XT1254 using Tapatalk
tnsaleen
Nashville, TN
No one has any input on what to do on the sway bar? I figured there would be alot more interest in this... Oh well.
tnsaleen
Nashville, TN
I have talked to Jeremy. He has a radiator support but it won't work with my down pipe, and he doesn't run a sway bar. I'd really just like to know if adjustable end links will raise it before I go spend $150 dollars on some
retfr8flyr
The Old One
Providence Forge, VA
They make a radiator support bracket, with sway bar mounts, that could possibly give you the clearance you are looking for. Never mind.
tnsaleen
Nashville, TN
Awesome. I never knew they made that many sizes. Looks like I should be able to get something that will work just fine
tnsaleen
Nashville, TN
More pictures of the hot side coming along. I had to modify the passenger side pipe for the down pipe, hopefully tomorrow I will have the pipe from the merge to the turbo complete, then I'll finish the pipe that connects to the over the axle pipes.
Hopefully 4 fingers is enough clearance between the Bell housing and pipe. It's about 9/16"
tnsaleen
Nashville, TN
I made brackets to lower it so the down pipe will clear. They are not installed yet and I just have the top saddle strap bolted to the lower hole for now
tnsaleen
Nashville, TN
Cross over pipe done
Fans installed
Slowly but surely it is coming together. The machine shop is taking alot longer than. I expected them to, oh well. Hurry up and wait!
Oil filter adapter block. The on3 one wouldn't work because of the coolant hose size. I know its MMR, and everyone hates MMR (including me) but this was the only option I could get since FRPP doesn't make a relocation kit anymore.
weather man
Persistence Is A Bitch
MN
Freedom racing also has an adjustable front sway bar link.
tnsaleen
Nashville, TN
Sway bar links have been ordered from white line. The hotside is done minus the y pipe to connect to the over the axle pipes, the wastegate flange, and cutout flange. It turned out as good, if not better than I expected. I'll post pictures tomorrow.
Now for the next question. Precision or rial wastegate?
