Now isnt this better than Mustang forums !
Oh GOD yes!
O.K. I'm going to kiss and make up now.
I am trying to eliminate the rake that our cars suffer from. Some like it I hate it. As it sits now the rear is still 1/2" higher than the front. Also the gap between the rear tire and the fender is shrinking nicely.
<<SNIPPED>>
Point one: The very act of cutting the coil, unless you use a waterjet, will compromise the temper of the spring steel and alter the rate of the spring (downwards).
Point two: cutting a coil off without increasing the spring rate creates a net reduction in suspension travel at a given loading. For the sake of argument (simplified for clarity), if the stock spring rate was 200lb/in, and had 4" of travel, it would take a 800lb force to compress the suspension to the bump stop. If you cut 2" off, it will only take 400lbs of force to put it on the stops. If you install 2" drop springs, but up the rate to 400lb/in, then you will still have only 2" of travel, just like the cut springs, but it will take 800lb of force to put it there, just like the stock springs.
Point three: Personally, I think the pics of the early iron sitting in the weeds are fantastic. Those are beautifully restyled cars, particularly the last one! HOWEVER this is a sub-forum dedicated to actively using our cars in an open-track or autocross environment, and asking about cosmetic suspension mods is out of place here. Not a social gaffe, it's just that the populace of this sub-forum is rabidly focused on "how will it handle," and while we all appreciate a nicely-done car, we're a lot more interested in function over form.
Point three: lowering the car will compromise the suspension angles. Period. That can be compensated for, but if you're of the mindset that cutting springs is the proper way to adjust suspension height, then the required work to compensate for the compromised angles will be far beyond your interest to execute.
Summary: My car is by no means a 4x4, but over the winter, it's losing some of it's drop, since the performance is suffering far too much due to the lowered roll center, and shifted anti-squat and anti-dive angles. To you, beauty is having no rake. To me, beauty is being able to threshold brake with R-compound tires, and not have the rear end wiggle like an over-excited puppy...
You are absolutely right I am in the wrong section of the forum.
I appreciate your explanation of how one can affect the function of a spring by cutting it.
In the end for me it is about beauty.
