While we rarely see eye to eye on almost anything, I
will agree with Sam on this one - after driving many solid axle cars with PHBs and Watts, in autocross and road course conditions,
I will only race my own cars with Watts Links. If I thought I could shave 0.1 sec a lap on my Time Trial S197 by adding a PHB I would do it... but I know better. We added a Watts and dropped time. No, we didn't do a scientific test on this one part, other than noticed a trend of "going faster" at the 30+ events we race this car in per year AFTER adding a Watts. The difference in feel was also unmistakable.
There are both scientific reasons as well as intangible feel differences between a Watts a PHB that are real and quantifiable. You won't see real solid axle race cars built with PHBs unless the rules require it (or individual racer's budgets or "mindsets" preclude them).
The GT-1 car above is owned, built and raced by a buddy of mine. 2200 pounds, 750+ hp SB.2, 14" wide slicks, lots of aero. Does it or any other tube framed solid axle RWD car have a PHB? Of course not. It has a WATTS LINK... and one that is mounted to the differential pumpkin, UNDERNEATH the car, for the lowest possible rear roll center. It isn't bolted to the axle tubes or utilizing a Panhard Bar. That's just not how its done on Real Race Cars (TM).
Click above to see the axle movement on an S197 with a edit: BMR panhard
The amount of lateral axle movement on an S197 Mustang with the OEM
or even an aftermarket PHB is ridiculous. Watch this "wheel cam" video above that we shot about a week ago on a 2012 GT. This was in a somewhat large autocross (3rd gear) using the (edit)
BMR panhard and 285 street tires. Just watch how much the axle moves side to side under lateral loading and vertical movement...
inches. This is from the PHB flexing, the bushings deflecting, and the natural "arc" that a PHB moves through as the axle goes up and down (a Watts Link doesn't move in an arc, but rather stays laterally fixed with vertical axle movement)
Of course an
aftermarket PHB is going to be slightly stiffer than the OEM stamped steel piece, and would likely have poly instead of rubber mount bushings, but it still has a magically moving Roll Center that changes with axle movement, and still moves the axle in an arc - two things a Watts Link just doesn't do.
My TT3 Mustang is still a dual purpose street/track car, and I even autocross it, too. For that reason I use (and sell) the Whiteline Watts Link kit, which mounts to the differential through a massively strong (8 pound!) cast aluminum rear differential cover. This cover is worth the extra unsprung weight is adds, in my opinion, as it holds more fluid, sheds heat a little better than a stamped steel piece, includes bearing preload studs, and has provisions for a diff cooler. It isn't legal for two SCCA autocross class until 2014 (or 2015?), when it is again after a rules change we asked for goes into effect. For 99.99% of you out there, that temporary rules restriction is absolutely meaningless.
There are several fine examples of aftermarket Watts Links kits for the S197, and they each have their Pros and Cons. The Cortex, Griggs and Fays2 have metal/spherical bushings, which are great on a race car. These bushings, however, have a finite lifespan and once they wear they begin clang and bang around. For a race car, that's nothing new - you just replace these periodically. Many people use these kits on street driven cars and just deal with the noise and/or replace these parts annually (they sell rebuild kits). I've driven many cars equipped with spherical bearing Watts Links and can't stand it, but for a race car I get it.
For a dual purpose car I feel that the elastomer bushings in the WL Watts is a better way to go, as they don't make noise and after a year of HARD use we haven't seen any additional deflection or wear. And we push the car HARD with 12" wide wheels, lots of aero loading, and have plenty of wins and track records using the WL product.
Another pro/con issue we hear talked about is Unsprung Weight differences between Watts Link designs. I feel this one is a bit overplayed, so I will explain. The difference in unsprung weight between a PHB or one version of a Watts vs another is around 8 to 12 pounds. If anyone is a cheerleader for reducing weight, it is us. We have a long history of weighing anything and everything on an automobile, and publishing that information, so people can accurately know what parts add or reduce weight. In some cases the aftermarket/race part weighs more than the OEM part it is replacing, because the race part needs to be stronger or configured differently.
Now I will agree that lowering the unsprung mass on a car is
usually a good thing, and racers will go to
certain lengths to chase tens of pounds of unsprung weight. One of the best places to do this is replacing the boat anchor OEM wheels or cheap Chinese knockoffs with wider yet lighter wheels. Losing wheel and tire weight helps both because it is unsprung weight AND rotating inertia.
When you factor in the
weight of an iron Ford 8.8" solid axle in the S197 these small differences becomes a bit less meaningful. These
8.8" axle assemblies weigh about 175 pounds. This is a rather large number, a big hunk of unsprung mass. Now add in the weight of your wheels and tires on the rear axle. A good, strong and wide wheel and tire will approach 50 pounds per corner. So that's another 100 pounds of unsprung mass. So will you notice an 8-10 pound difference off of the axle locating device when you have nearly 275 pounds of unsprung mass on your Mustang? Mmmm.... probably not.
I'm not making up these numbers. I have shared the weights of the OEM PHB and Whiteline Watts many times, and will do so here again. The images above are of each part in the Whiteline Watts Link kit for the S197. Some of that weight is sprung, some is unsprung, and some items are half and half (the locating arms). Here's the real numbers:
Sprung Weight:
Watts Tower Mount + Hardware = 4.50 lbs
Watts Tower Reinforcement Bar = 4.20 lbs
Lateral Locating Bars (1/2 sprung) = 3.04 lbs
Total sprung weight =
11.74 lbs
Unsprung Weight:
Differential Cover = 8.12 lbs
Propeller and Bolts = 3.60 lbs
Propeller Bracket = 2.72 lbs
Total unsprung weight =
17.48 lbs
Total Whiteline S197 Watts Link kit =
29.22 lbs
In the end, arguing for a difference in unsprung weight of 8 to 12 pounds on a rear axle assembly that weighs around 275 lbs is... kind of chasing rainbows, in my opinion. None of the Watts Link kits are significantly lighter than one another (all about 25-29 lbs), and all will weigh slightly more than a PHB set-up. These are 3600 pound cars, so let's not forget the magnitude of mass on the cars we're talking about here, too.
You have to make a decision if the benefits of adding unsprung weight outweighs the negative effects of that change. In this case we feel the small amount of added unsprung weight from the WL Watts far outweighs the downsides.
Anyway, that's my 2 cents. Your Mileage May Vary. Don't eat any wooden nickels.
Thanks,
