Why compression damping?
I've been giving the question of springs and dampers a bit of thought, and there's one thing I haven't been able to understand:
Why do dampers have any amount of compression damping at all?
I can think of some downsides to having it, namely that you wind up with an effective variable spring rate on compression that is dependent upon the speed at which the spring is being compressed, thus reducing the ability of the suspension to follow sharper changes in the surface, increasing the "harshness", etc. In addition, you wind up needing to use less spring rate for a given set of conditions, when maximizing the spring rate almost always results in better overall handling.
But what are the upsides? I can't think of any.
Hence, my question. It seems to me that the ideal setup would have a damper that operated in rebound only, with spring rates being used to tune the compression side of things. What am I missing here?
