Wotbox + 4r70w
Fordbanger
Grand Bay Al.
I was just wondering has anyone done it if so was there any issues? If it was covered before I apologize as I did search.
dysan
Dis-Member
Williamstown, N.J.
Been running mine since I put the 4R70W in..what kind of issues could there be? All you would be using it for is the 2-step (unless you also use the window switch for nitrous) and people have been using 2-steps in them for years in the S-95 mustangs where the 4R70W is from.
You have to turn off the no-lift shift feature obviously.
Fordbanger
Grand Bay Al.
I just was wondering if the clutch safety switch was a issue. Didn't know where it got the signal for the 2 step to activate . I would also be using it for nitrous control too. Just curious thought I'd ask.
dysan
Dis-Member
Williamstown, N.J.
I assume you will have a transbrake in your 4R70W right? If so then you use the switched power from the button for the trans brake to activate the 2step.
Dark_horse
KC MO
thanks for that as I was wondering the same as well... since I already have the wotbox installed
dysan
Dis-Member
Williamstown, N.J.
I don't know if the brake pedal sensor outputs +12v or not when you press the brake but I'm sure there is a way to use it whether you need to tap in to the brake pedal switch and use a relay or if it outputs +12v when you depress it then just use that.
Fordbanger
Grand Bay Al.
cool, thanks for the info. I haven't installed the wotbox yet. Was just think about future plans before I did. wanted to make this would be the correct route or not.
