ZL1 Addons Jackpad warning!
BleedinBlue
Eureka, Mo
So this just happened. I'm pretty sick right now.
I was jacking the car up and it was almost to full height. The jackpad split nearly in two, the car fell off the jack. The side skirt was ripped off and my fender was trashed.
The jackpad was bought a year or two ago from ZL1 Addons. It's a polymer/plastic style. I KNOW it was seated on the weld properly. My jack is a flat pad style. There is NO reason this happened other than their product failing. I just sent them an email but I don't expect them to do anything but blame me. It looks like they don't sell the polymer style anymore, the new style they have looks aluminum.
Even my wife is saying now that this car is cursed, maybe she's right.
fdjizm
Drag Queen
It's made for chevy, maybe there was a recall?
On a serious tip, that is pretty fucked up but that thing was designed to lift a tank like the zl1, no way it should have failed on a mustang.
BleedinBlue
Eureka, Mo
Luckily I wasn't placing a jack stand under the car when this happened. The car was almost jacked all the way, 30 seconds later and I would have at least had my arm and shoulder under the car.
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
OMG!!!! Thank GOD you were not injured or worse!!!! The owner was a little slow responding to emails when I bought mine but he did respond. I hope you hear back from him. And FWIW, mine is aluminum.
In reference to your car's injury, at least your car is black and matching paint will not be an issue. Let us know how it goes!
tjm73
of Omicron Persei 8
Rush, NY
That plastic thing looks cheap. Glad you weren't under it when it failed.
Maybe this is a dumb question, but why don't you (or anyone else) put the jack in under far enough to lift where the front cradle bolts to the unibody?
Phil1098
Central Illinois
Ugh, that literally makes me sick to look at, beautiful car. Thank god you weren't under the damn thing when that failed. I always jack farther under on the built in rails. They don't deform and it's way safer. Also you said it was at nearly full height, if the jack didn't roll some as the pad goes through it's arc it is pulling a side load on that pad, may have been why it split. (that and it's a POS part made of plastic)
Department Of Boost
Alpha Geek
A fine example of "just because someone is selling it, it doesn't mean it's good".
I would guess half the stuff on the market is junk. Buyer beware.
BleedinBlue
Eureka, Mo
Thanks guys.
I don't think the body shop I will go to is open today, so it'll be next Thursday before I can get it in for a quote.
With the car being so low, even with the low profile jack, jacking it up closer to the edge was easier. I usually jacked from the edge then put the jackstands further in. Doing this made it easier to fit the jackstands into place too.
The company that made the jackstands is a vendor on another forum. At the time I bought the thing I could have sworn I watched some torture test videos, and there were tons of positive reviews. I trusted it because of this. A costly lesson indeed.
I don't even think there's a way I can use this as an excuse to upgrade anything on the car, lol.
Unreal
Gilbert, AZ
Never used anything like that to lift any car I've ever owned. Really don't see the added risk being worth it.
brent_G
Custom User Title
Vass, NC
Totalled.
How much for the wheels?
Jk. Glad you didn't get smashed
Scott_0
OxFORD, Pa
glad you werent hurt man, sucks about that damage. I would have personally went with an aluminum if it were me........
Bullitt 3309
San Antonio, Texas
Fuck OP, I bought a set of those year ago I also got the UPR metal ones as well. Definitely want to see what they say about the failure!
BleedinBlue
Eureka, Mo
At the time they didn't sell the aluminum. I'm guessing these things started splitting and they changed their design.
At the time there didn't seem to be any real risk. I guess I just fell for their marketing...even being plastic, they seemed bulletproof.
I'd dump them if they're the older plastic version. I bet the aluminum ones like Darren has would be perfectly safe.
wbt
Why not just take the cup off the jackstand and use the flat surface of the jack to jack the car with? I have done that many times without issue.
