Flapjack
Lunatic engine swapper
Finally got around to a dyno run on the car. Keep in mind, this is only 7.5psi on the stock engine.
Dyno Sheet:
Video:
A few notes:
- Peak boost is at around 3700 rpm, which is fine by me.
- The shop's MAP sensor says 8.x psi, but I'm pretty sure it's not correct. The wastegates are set up with 7.5 springs and my digital boost gauge shows anywhere from 7.5 to 7.6 psi at WOT.
- AFR is pig rich at around 10.4. Hoping for another 25-50 hp when the AFR is closer to 12.
Dyno Sheet:
Video:
A few notes:
