I am thinking about a KB Stage 2 blower for my '05. I plan to add good rods and pistons to my OE crank and run the blower at ~12 psi. I will upgrade the oil pump too. Also will add higher capacity oil pan and windage/crank scrapper. I will do an oil cooler too while I'm in there. Everything else should remain stock.
No plans to run slicks or spin it past the stock redline. Aside from a clutch upgrade that I expect, what else might need attention? If the tranny goes, I'll do a ProMotion rebuild. Supposed to be good for 700hp. But I'll worry about that when/if I need too.
Secondly, what is the max psi you can safely run on 93 octane common pump gas?
Looking for real world experience and opinion from those that have the setup.
Thanks guys.
Thanks guys.
