putting this big boy in
Towelly
Good stuff. I too would LOVE to see a track vid of this thing. Gotta be nuts on the big end.
toorbeenee
turbine lunatic
dubai
Its Suhaili right? Are you still on here bud?
Hi josh
Yes bud I'm here. Been little busy. Mustang is running strong. And enjoying the 15. Both running strong
JoshK
Modder AKA Fuel
Nebraska
Good to hear. Did you ever get a boost vs rpm done with that gt47? I have something similar going in soon
toorbeenee
turbine lunatic
dubai
No bud. I did not. I have the data log from my last run. But it's motec file
JoshK
Modder AKA Fuel
Nebraska
What kind of radiator are you running in this car? I see you have a radiator cap on the radiator on one end. Did you have that welded to the radiator or did it come that way?
toorbeenee
turbine lunatic
dubai
Hi josh
I fluidyne radiator. And I welded the neck to it. It's from jegs. They sell it ready with he cap. I don't have the part number on me.
JoshK
Modder AKA Fuel
Nebraska
You can get them with the coolant cap already installed on the radiator? I can't seem to find that.
toorbeenee
turbine lunatic
dubai
No bud. The radiator came without it. I had to cut and weld the neck.
The neck comes with cap from jegs.
toorbeenee
turbine lunatic
dubai
Back again on board, did major change in the stang, the vid speaks for it self below is what i changed. sorry its a dark vid, ill try to get another one outside. And my pass At Yas Drag strip.
1- Changed water to Air cooler. trunk mounted with ice box.
2- Ice cooler for the TH-400.
3- Front mounted the turbo with side exhaust,(can be changed for daily driving to the back mufflers).
4-Smaller radiator to make room for the turbo.
5- Re allocated the ECU behind the fender.
6- Re allocated the battery to the trunk.
lots of things i forgot to add, please feel free to ask.
did a pass on the 17th last month. 9.58 @210 klm. Ran out of gear. now in the process of changing to 327. hope to get a better time. car had 3.55 gears.i need to change my sig i know lol.
side note: AC and power windows still work LOL.
Above work was done over the summer time since its very hot here and cant drive it. all the work was done from May till November.
Special thanks to Ed.(silverpoison).
travelers
Eastern Pa
That is a wild setup. Congrats on the 9.58 and yea it does get a little hot in the summer.....Lol
