MindIfISmoke's? Built Part 3.
MindIfISmoke?
Wrecking Crew
Puyallup, WA
Shiiiiiiittttt. Well looks like I'm going return style.
Anyone have any cheap ways to do this?
I need a
Regulator
Lines
Fittings
Wiring harness
Filter
Y block.
Here's my fore hat which I believe works in either return less or return.
And the top with the stock line adapter removed.
JoshK
Modder AKA Fuel
Nebraska
Should you just need a return line with fittings, a couple relays and maybe a hobbs switch? Both of your pumps on your fore hat exit the hat on one fitting now don't they? Can't the stock feed line still be used?
These are honest questions to help with the switch so don't use them as advice matt.
05stroker
Never enough power guy!
Bullard Tx.
Yours doesn't have the screw holes for the return pot to mount to or the tube that returns the fuel to the bottom of the pump in the tank.
MindIfISmoke?
Wrecking Crew
Puyallup, WA
Justin at fore says I have the old style hat. He has set me up with the fittings I need to have on the top of the hat. My hat is different then yours.
JeremyH
3V Fuel Guru
Virginia Beach
05stroker
Bullard Tx.
Yup thats the original hat, there is a screw in 8an fitting for the return.
You will want to run a 2 to 1 y block for the -6an feed from each pump to the y and then 8 an to the rails, and a full -8 an return line.
Here is the y block
http://www.foreinnovations.com/product_p/20-100.htm
And one of these regulators.
http://www.foreinnovations.com/product_p/15-100.htm
Then its just the fittings and lines themselves you need.
So the original design didnt have the return tube to the bottom of the hat and just dumps in via the -8an fitting at the top?
Each pump has its own exit. I don't think i can retain the stock line.
With the stock line adapter installed, does it cover the return line port?
MindIfISmoke?
Wrecking Crew
Puyallup, WA
What so you think Jeremy? I think this is the easiest way.
With the adapter installed I may be able to use it.
JeremyH
3V Fuel Guru
Virginia Beach
No it doesnt.
Not sure if Justin has the line to the bottom of the tank for him or not, if not you can just run like a 45 degree barb and piece of hose down to the bottom of the tank for the return to prevent splashing cavitation when your at less than 1/4 tank etc.
Ehh, its not the way I like to do things, covering up a problem with new parts to bypass it, but hey its up to you man.
It is indeed an easy solution though as long as it works out. lol
It would bug the crap out of me not figuring it out but thats me, I may be weird in that I enjoy trouble shooting things finding the problem and fixing it. lol
05stroker
Bullard Tx.
how did you mount the mechanical gauge to the rail? drill and tap? I believe we have the same aeromotive rails... also where did you get your vacuum manifold?
Gauge is mounted with an adapter -8 female to -8 male with a 1/8 npt female for the gauge. Vac block came with the Procharger kit and I just drilled and tapped more fittings.
JeremyH
3V Fuel Guru
Virginia Beach
Part of the evap system, I'ts the solenoid that lets gas fumes from the the tank into the manifold. iirc
