rford426
Resident 5.0 H8R
Yeah dude they can be a headache I think we've all been there
Yup thats the original hat, there is a screw in 8an fitting for the return.
You will want to run a 2 to 1 y block for the -6an feed from each pump to the y and then 8 an to the rails, and a full -8 an return line.
Here is the y block
http://www.foreinnovations.com/product_p/20-100.htm
And one of these regulators.
http://www.foreinnovations.com/product_p/15-100.htm
Then its just the fittings and lines themselves you need.
Each pump has its own exit. I don't think i can retain the stock line.
With the stock line adapter installed, does it cover the return line port?
So the original design didnt have the return tube to the bottom of the hat and just dumps in via the -8an fitting at the top?
What so you think Jeremy? I think this is the easiest way.
Save me the trouble, what was the power you made?
650 before.... going for more now
how did you mount the mechanical gauge to the rail? drill and tap? I believe we have the same aeromotive rails... also where did you get your vacuum manifold?Then yes, this is the easiest way.
Gauge is mounted with an adapter -8 female to -8 male with a 1/8 npt female for the gauge. Vac block came with the Procharger kit and I just drilled and tapped more fittings.how did you mount the mechanical gauge to the rail? drill and tap? I believe we have the same aeromotive rails... also where did you get your vacuum manifold?
