Department Of Boost
Alpha Geek
- Joined
- May 26, 2010
- Posts
- 8,808
- Reaction score
- 31
Thought you roadrace guys would dig this.
Huge thanks to 908SSP/Alex for doing this project with me. He worked his ass off on this. It wouldn’t have been possible without him.
Eventually the blue 2007 will be going for some big time top end in the standing mile (220+). And a lot of going fast is aero. We just finished the belly pan, which was a HUGE job. We have over 70 man hours and $600 in materials in the job.
We used 6mm aluminum honeycomb board for the panels then heat shielded the crap out of it with DEI stuff. The board is crazy light as well as very, very stiff. All the panels, brackets, fasteners, exhaust wrap, etc weighs under 20lb. Not too bad.
I may be crazy, but I swear I can tell that the bottom of the car is flat now. I did a high speed test run Saturday night and the car certainly didn’t feel like it was trying as hard to punch a hole. I’ve spent a lot of time racing in the 180-200mph range. I think I’m a pretty good judge of aero feel.
In the one pic you can see the splitter and the OEM 2010 “heat extractor” panel. Were going to test replacing the OEM 2010 “heat extractor” panel with a solid piece and see if it increases underhood temps. If it doesn’t we’ll use the solid panel, it should be more aerodynamic.
Next project, maybe next week, is to finish up the rear diffuser and add a trans cooler.
