sholzer
Here is another video of the rear end with a panhard moving through its arc/deflection on the stock 255 pirellis.
Wow! That's impressive.Whoops, sorry, BMR panhard bar:
http://vorshlag.smugmug.com/Racing-...99281_2z8QJb#!i=2664718105&k=Mz2bTZt&lb=1&s=A
Is that a stock PHB?
Do you know which one of their bars it was? The one with the adjuster in the middle was always a bit scary.
Yeah it's the one with the adjuster in the middle
http://www.flickr.com/photos/98619788@N08/9525732847/
Liberal use of red loctite has made it stay put to the point where I don't notice it. It doesn't make any noise, and the bushings look good after ~20k miles. I've actually been remarkably satisfied with it in every respect other than that it's not a Watt's Link.
You lost me. Was it loose in the video? And red Loctite cured it? Or does it still deflect that much with everything tight/Loctite'd (IDK how you would spell that).
Despite what I see in both of those videos, I can't believe the PHB deflecting that much. The bushings would have to collapse to essentially nothing and then rebound to their normal shape.
Marks video is shot from the passenger side with the BMR PHB. Scholzers is shot from the drivers side with a stock PHB. The deflection in Mark's car looks worse than a stock one to me. I don't think for a second that the BMR bar flexes more than the stock one. Too many variables there to really conclude anything between speed and grip adding up to actual lateral acceleration differences between the two cars.
Anyone have a similar video with a watts link installed?
Looks like a pretty noticeable difference between the Watts and Panhard in horizontal movement of the rear axle. At least you know the Watts is working as advertised.
I was going to say just the opposite actually...there are three very different suspension packages between the videos we've posted, but IMO the Watt's video doesn't show a ton less lateral displacement than that panhard videos do.
