ATI Super Damper, which ARP bolt?
golkhl
Las Vegas, NV
Going to be installing an ATI Super Damper(part no.918039) on my 2008 Bullitt, and need to know which ARP bolt I should be using.
ARP 156-2501 which is the stock length replacement, or ARP 206-1001 which is longer. I ordered the longer ARP 206-1001, but later found this is the preferred bolt for the aftermarket crank guys. I am installing it on a stock crank and don't want to trash the threads. Any help/info. is greatly appreciated.
Check Scott's build thread. I believe he used the 206-1001.
I went with an IW 10% overdrive crank pulley and used their supplied bolt, which is about 1/4" longer than the stock bolt. The pulley was thicker than the stock pulley and the stock bolt only had about 3/4" of thread engagement.
golkhl
Las Vegas, NV
I ordered ARP 206-1001 based off the info. found in Scott and Todd's build threads, but later realized that they both had aftermarket cranks. That is why I am concerned it might be too long for use in the stock crank.
I had both and was able to try both. You could measure the depth of the hole and compare it to the length of your bolt sticking out the back of your damper/crank pulley.
one eyed willy
Pizzle fo shizzle
Lakeland FL
The difference in bolts was because of the cranks. The Kellogg cranks don't thread to the end like a stock crank, so it needs a little longer bolt.
Stock crank you should use the shorter bolt.
golkhl
Las Vegas, NV
I ordered the shorter ARP bolt and 18mm socket today, that way I have both available when I do the install. Looks like I will be installing the shorter ARP 156-2501. When the TVS install is done, I will put the ARP 206-1001 for sale in the classifieds. Thanks again for all of the help.
one eyed willy
Pizzle fo shizzle
Lakeland FL
I'd buy the longer one from you, I'm actually using the shorter bolt when I should be using the longer.....PM me
