Then that is the chance you take and common sense says that is not a good plan.
Make sure it's got billet oil pump gears. ...Ford has been having a little issue with them not having em lol.
My parts guy is about as good as it gets. Searching 2014 Mustangs. There is no reference other than the 4 bolt water pump pulley. However, when searching by Witt's vin #, it does list a separate part # and specifically references a 3 bolt water pump. It also says (Some 2014 "Post Job 1") - Very Odd.
Edit:
The reasoning appears to be clear upon researching part numbers. The cost of the new pump is about 60% of the 4 bolt.
3 Bolt Water Pump - BR3Z 8501 J - MSRP $82.38
3 Bolt Water Pump Pulley - BR3Z 8509 HA - MSRP $9.97
4 Bolt Water Pump - BR3Z 8501 H - BR3Z 8501 H - MSRP $143.47
4 Bolt Water Pump Pulley - BR3Z 8509A - MSRP - $20.13
I spoke with the engineers at Vortech / Paxton.
The OEM Pulley should work ok. Vortech / Paxton provide a pulley with larger lips to help prevent any belt walk. There should be no issues with running the oem 3 bolt water pump and pulley, but a car will be in house soon for testing to know for sure.
I believe it is slightly smaller, but I don' t think it's enough that will require the idler adjustment to be moved with a stock pulley with a Paxton (3.8). Those with a Paxton that is pullied down one to a 3.6, or a Vortech might.
We haven't had one in house to know for sure though. If you have a 3.6 when you install, if the tensioner appears to have too much play and is close to bottoming out, you will want to move the idler over one spot to tighten up the system.
The 8 ribs water pump pullies at some point, will more than likely be getting re machined to accept both bolt patterns. Initially if your plans are a competition kit or 8 rib upgrade, your easiest option would be a 4 bolt water pump from Ford. If need be after testing, the 6 rib pullies may end up with the same bolt pattern treatment.
Just wanted to put info out there so no one has any surprises.
This right here is a perfect example why I choose you to purchase my Paxton kit and have plans to buy the rest of my mustang go fast parts.. Question comes up that the makers themselves don't know about and boom you get answers. I still haven't dug into installing my kit or all my other parts because I crashed my dd right before xmass and it set me back about 6 weeks. Good news is it's just going to be a little warmer in the garage once I start. I'm seriously thinking about doing my oil pump gears now since I have a late 2010 build date. I just want the full supporting mod list to be safe on the stock pulley. Cheers
Well finally pulled the trigger on a Paxton kit from terry a couple weeks ago. Will be doing the install this weekend. What will be going on this weekend is...
Paxton 2200SL 3.8 pulley
JLT CAI
ID1000's
FORE dual 465's return style fuel system (for E85)
JPC T-bolt kit
JPC coolant tank
Will be having shaun at AED tuning it since he is local to me.
For those of you with the Boss 302 intake manifold; did you have to extend the throttle body wiring or can it be stretched to reach? It looks pretty close, so I thought I'd ask here before I started cutting and soldering. Thanks!
The throttle body adapter kit for the Boss 302 comes with an extension harness.
I am a total noob to fuel systems. Running a BAP now, and I do see a built motor down the road, with a goal of 800hp, maybe even 900-1000 max if I switch to e85.
What is the simplest "bolt-on" fuel setup I can run? Nothing too crazy but safe.
Fore innovations.
thanks for the biz. And a great way to start. The fuel system out of the gate is a win win. Should be a beast on e85.
^^^ Good timing doing the billet gears. Great how to thread also. I wish I had done those first on mine instead I will be pulling the blower and stuff back off mine soon I'd say to do the billet gears. Your car should be strong. Just had a buddy do a Paxton and Shaun tuned it. He is very happy with the power and the street manners.
JLT CAI
ID1000's
JPC T-bolt kit
JPC coolant tank
