JeremyH
3V Fuel Guru
how much did the cams cost u Jeremy?
They are quite affordable, I paid more for an off the shelf cam the first time around.
So mark at bullet said the cams Bruce linked would not be good for me. There is too much duration. That's stage 3+ livernois levels.
He said I'd have back pressure issues with that much duration. That would be more suited for something like an 80+. I'm just assuming jeremy spec was higher since he has to spin two turbos. He gave me the 222/227 with .525/.525 @ 115.5.
I only live once and I said I was going to do it right. I'm going to do those cams with the pac springs since I can still use stock retainers.
Call up mark tell him we want to do a group buy.
I'm sure they will work out well I just can't afford to do it twice if you know what I mean.
The turbo is going to chop up an cam sound unless you get a cam that will kill your power on a turbo car. The cams I am running right now don't have much noticeable sound with the turbo on the car, but here is a vid with just open headers and these cams. Also a pic of the cam card. I will try to get an idle vid this weekend with the new exhaust and turbo kit back on the car with these cams. Vids of the dyno runs can be seen in my build thread from page 24 on with the current cam setup.
