GallopingFord
I'm Cam - Mr. Indecisive
Maybe a little darker.
Ordered 4.10s, install kit, and a solid pinion spacer. Just need a new diff and fluid. Too bad I can't afford a tru trac right now.
I appreciate the offer, but used gears are a gamble I'm not willing to take. They are cheap enough that its not worth the headache! I have terrible luck when it comes to doing stuff on the cheap. I always get bitten in the ass. Which is why I'm ordering a new diff instead of repacking the clutches lol.
Gloss black or even matte is not an option.
So far I'm looking at sandblasting them to bare aluminum and then clear coating that, another dark grey with metallic flake, or dark bronze. I'm leaning towards bronze ATM to change it up, but not positive.
Cam, these are all good ideas. The right bronze can look very good on black. The wrong bronze can look like crap. Careful with whoever powder coats your wheels. I've had bronze come out like poop brown. The OG standard for the right hue is Volk Racing's bronze. What sucks is that it's anodized, so it's tough to replicate, but you can get close.
The guy who repairs the wheels at our store does a really good job at replicating wheel colors. I'm like 90% sure I want to do dark bronze though. You are right though, bronze has a ton of different finishes. I want something with a metallic flake, but satin finished. For some reason after touching the current finish on the Rotiforms, they have some terrible grime grease marks that do not want to budge.
The sandblast clear or with a tint would be very nice too.... damnit
Try using WD-40 on a rag to remove the smudges.
The Rotiform wheel above is a machined finish with clear over it. Sandblasting the wheels won't have the same finish (at all). They'll look like that blue M3 above. It still looks good, but it'll resemble a light cement color rather than a machined finish.
...sometimes the brushed/tinted finish is magical though.
Finished up my wiring for the battery relocate, sadly my battery is most likely done.
What car is this? Ford uses U-bolts for the swaybar mounts? Earlier model?
What is that, and who makes it? I was going to just put a small aluminum box there, run the cables from the battery to the box, use some bulkhead posts and connect the OEM cables to it.
