2015 Power numbers
tjm73
of Omicron Persei 8
Rush, NY
Wonder if the power to weight ratios are roughly the same.
BMR Tech
Traction Vendor
Tampa, FL
Going off advertised power ratings:
Ford:
Boss 302 = .122 HP per LB
13/14 GT500 = .172 HP per LB
2014 GT = .116 HP per LB
2015 GT = .117 HP per LB
*03/04 Cobra = .106 HP per LB
GM:
C7 Corvette = .138
'10+ Camaro SS = .109
'14 Camaro Z/28 = .131
'14 Camaro ZL1 = .140
*2002 SS Camaro = .095
Captainstr8edge
Hardcore Superhero
North shore, MA
GrabberBlue5.0
Gold Member
Louisville, KY
From everything I have seen, and heard, the rods should be similar to the Boss 302 pieces. If that is true, then this engine should handle 700rwhp pretty safely.
I am going to get mine, and make 750-800rwhp. We will see how long it lasts. My goal is to take the car into the 9's with only a poweradder, tune, and some minor suspension tweaks - on a DR.
According to motor trend they have boss connecting rods.
Is ford changing anything physically in motor or did they find power in the tune?
Heads, boss cams, larger valves, boss connecting rods, CMCV's, boss valve springs... Or so I've read second hand anyways
tagle281
Corpus Christi TX
Probably the same potential as a 11-14 GT with less weight. Curious to see if the irs is worth the weight. I can see people swapping them out already.
Captainstr8edge
Hardcore Superhero
North shore, MA
From what I have seen the 12-14 5.0 is good for around 600? Kim seems to think 700 will be safe with the added boss connecting rods.
05yellowgt
Dayton, OH
Actually, the exhaust cams have 1mm more lift than the boss exhaust cams. 13mm I think. The piston tops are also revised to accommodate the larger valves.
lostsoul
2014 vett or 2015 stang..
Gay Area
Fuck them... add weight and piss ant power added.. This one says 430hp
fuck it.. Ill wait next year for the gt350 or give up and do a don. I'm pretty pissed.. fuck you ford..
nasty281
MODIFIED STANG
memphis
And a solid rear axle. Cough cough..
HEMI LOL
The Feast and The Famine
Fircrest, WA
lol really?
interested to see the power curve with CMPs the new intake mani has.
87lbs of weight gain for how much wider this car is and IRS is remarkable imho.
i can see 15 being 2010 all over again, as a new camaro is due in 16 and I'm sure it will make 436. then the 17 s550 will come with probably 450.
