swflastang05
Back for More
Congrats, that's awesome!
Jim,
You may be jumping the gun or reading more into what is there.
Brian (skwerl) may very well have just meant that the assembly portion of the long block is too easy/fun/whatever to pay someone to do it. I personally didn't read his response as a dig towards JDM.
680 is a lot of jam! Sheesh. Keep us informed how it is on the street.
I have no idea what the Gospel Mission is...
No bridges where I was... lol
I was here: 12719 28th Ave NE, Seattle, WA 98125
I thought you were at the place in Everett with a dynapack.
nice to see the car running good. Im getting hankook rs3 tires i hope they are enough for my setup... do i will semi slick tire=?
Looking for some help/advise...
Update: Still working on some driveability bugs (minor stuff).
First item is one that I am unsure whether its a drive-ability or a driver issue.
When I shift under WOT, the power shuts down like hitting a wall.
So, going WOT, lift, shift, release clutch/WOT...and that transition is HARD!!! It feel like the motor hiccuped/stumbled. As soon as you lift and then apply the power, its a violent transition.
Wondering if its driver or tune related...
And the fuel cut-off/RPM limiter is set really hard too. Is it possible to set the limiter a little more gradual/softer?
I need to discuss with Lito...
You need to stay off that limiter with a boosted car. I had Manuel set mine at 7800 so I could stay off it when shifting at 7200- 7500. The more power you make, the eisier it is to hit it and the harsher the result when you do.
