lito
That is not 36%, your are logging the lowercase PID not the DMR so the value is halved, so that is 72% actually, but that still is very good, you look to have enough room for the the alcohol test.
I paid $2.54 a gallon yesterday.
It's still over $4 a gallon here. One station has a monopoly and he takes advantage of it.
would there be any benefit to using a "y" block instead of jumping from rail to rail?
Running the rails in parallel, which I think is what you're saying here, is superior to running them in series. The reason is that if there is a pressure drop it's more uniform rather than affecting one side more than the other. That's less of an issue with a return system, but still.
stock filter OK to run w/ e85?
any issues from taking out the check valve? i heard it makes the car harder to start?
Also tearing into stock or gt500 hat isn't the most pleasant way to spend a weekend lol
I recommend a dremel, patience, and a lot of zip ties hahahaha
The stock filter works just fine. They are designed with flex fuel in mind. I've always run the stock filter, lines, rails, etc and never had a problem. So have millions of flex fuel vehicle owners.
