05stroker
Never enough power guy!
Intake popped right loose after I removed the coolant cross over and was able to drive a screwdriver between the head and delete plate to separate.
Now I am more confused then ever. I pulled the motor today and removed the heads. I see two areas on the copper gasket that are suspect due to the dark color. Take a look at these pics and let me know what you guys think. The good news is that the "pits" I saw where oil bubbles. Now where the hell is the oil coming from and why was cylinder #1 only at 115 and all the rest around 170 on the compression test?
I am very confused right now.
