Well this:
Got installed on the car. Both sides got poly bushings. The big rear bushings got a groove turned in them and holes drilled in it. Drilled and tapped the outer sleeve for grease zerks. Fronts got grooves and holes in teh bushings but no grease zerks installed in the arm as I busted the drill bit.
For those looking to do the fronts and are buying replacement front control arms like I did. The Moog high end front LCA's utilize a smaller front bushing metal sleeve than what Ford does. This means you either need to burn the inner metal sleeve out of your stock control arms, or you need to provide your own front metal bushing... I did the latter because access to a machinist who works for peanuts and viable metal stock was available.
Car got aligned today:
-3.0º of camber
-0.01 total toe (read: Zero total toe)
+7.2º of caster on driver side, +7.8 on the passenger side...
Rear alignment, while not adjustable, hasn't changed any:
driver side camber is -0.3º, right side is straight up zero (most likely a pressure difference...), toe is -0.12º total toe (driver side is -0.14º, passenger is +0.02º). Thrust angle is -0.08º
The hunter alignment rack said no steer ahead.
Pretty glad about those alignment numbers although a little more negative camber wouldn't hurt.
