lito
Any plans to do a write up for it? That would be an awesome swap. I've always loved driving EPAS cars. Plus getting rid of that noisy PS pump would be great too.
(as I wrote in DOB's car thread)
Sincerely, no. I can help you out if you want giving the specific pointers but is so damn straight forward to do I don't see need. Get the rack, test fit to find the bracket that needs to be welded, do the bracket and weld it, strip the harness from the 11+ and use the wires needed (this has a lot of extra wires like starter and alte IIRC), laid them out as needed, thick + to battery with it's fuse (you will probably just leave it as is mostly and reroute the alt wire so not to cut anything as it comes), ground to chassis, switched power to start/run power point at the BEC and CAN wires to PCM CAN wires at the body connector (mid connector on 3V PCM) Hi with Hi, Lo with Lo. That is it.
The only gripe I think there may be is the need for a higher alt than stock, IIRC coyote's are 160+ instead of the stock 130A of the stock 3V, the EPAS has a 100A inline fuse, yes, it use quite some juice when parking, etc.
