2008 ROUSH Stage 3 Build...Take III
AutoXRacer
Florida
Yeah, the new pistons are only a -11cc dish, that is not going to lower boost. It's upstream... Blower, rotors, throttle body...
thump_rrr
Montreal Qc,
I've been following this build from the get go and now I'm puzzled.
Didn't you replace the crank pulley for an under drive unit?
Let's assume the blower, TB, pistons, and heads didn't change for a minute.
If you reduced your crank pulley from 7.4" to 6.55" you would need to change your blower pulley from a 3.0" to a 2.6" to keep the same drive ratio.
DiMora
More Is Better
Fayetteville, GA
What is your current crank and snout blower pulley diameter and what redline do you have set?
Trying to calculate whether you have room to spin the blower faster and pick up a PSI or two...
My guess is the TB costs you a bit but I'd keep it "because streetcar"
AutoXRacer
Florida
I did buy an undrive pulley; we all though this blower was going to make more boost. I installed thE 6.55 first with a 3.0 upper and we only got 7 psi.
Then I swapped the 3.0 for a 2.8 and got 9 psi.
Lito told me to remove the 6.55 and replace the 7.40.
So with the 2.8 and 7.40 we only got 12 psi with a creeping peak of 14 psi past 6200 rpm. From the graph above, you can see the blower starts making boost starting at 6250 rpm.
What bugs me is that this pulley combo (2.8/7.40) made 16 psi on the previous motor. Technically I'm down 4 psi and 2 psi at 6250 rpm.
AutoXRacer
Florida
Current setup:
Upper 2.8"
Lower 7.40"
Max RPM 7500
My current TB is a dual 67mm.
If you are using that compression height with a 3.750" stroke it's still .030" more in the hole than compared to a normal stroker compression height of 1.200". If that's the case you will be down on compression and power. If you are using them with a 3.800" inch crank then they are likely sticking out of the hole.
Hopefully I've missed something else you posted because either scenario is not ideal.
Good thing I like to take pictures... LOL
So here is the MMR piston box:
-11cc
Now waiting to hear back from JDM to see what their pistons are...
hamish
B.C.
Not to be a technical dick here but you make "boost" instantaneously with that graph.
What cams are you using?
Did you time this motor yourself?
AutoXRacer
Florida
123450 timed at 4 degrees retards for a centerline of 109.
Yes, same cam timing as before.
Bruce, I have the 3.80 stroker crank; the piston tops or ring land was flush to the deck of the block. Piston did not protrude nor was recessed into the cylinder at TBC.
Not like you can tell anything from these pics. lol
Bruce, I have the 3.80 stroker crank.
If you are using 5.850 rods then your pistons are sticking out of the hole and into the head gasket about .012". That would push compression up quite a bit. I think you would of noticed any ptv contact. Did the assembler mention that the pistons were out of the hole? Did they take ptv measurements?
Maybe the info on the box is wrong. Is there any chance mmr used a used box to send the pistons in?
AutoXRacer
Florida
No he did not mention it...
All I know is when I set the TDC without the heads on, the pistons did not protrude from the block/cylinder. They were flush with the deck.
Frankly, I don't trust MMR. The info they give you is very inconsistent.
I wish I would have had my builder cc the pistons. But again in my innocence, I trusted MMR supply me with the correct parts. Not saying the parts are wrong, just wish they provided better consistent data.
AutoXRacer
Florida
Lito requested I take pictures of the plugs... Here goes boss!!
Cylinder 1
Cylinder 2
Cylinder 3
Cylinder 4
Cylinder 5
Cylinder 6
Cylinder 7
Does 7 seem a little wet...?
Cylinder 8
I did have additives in the tank...a whole can of Sea Foam and 1/4 can of Torco...
AutoXRacer
Florida
Regarding the piston tops... I think the coating is gone!!
What do you think?
Cylinder 1
Cylinder 2
Cylinder 3
Cylinder 4
Cylinder 5
Cylinder 6
Cylinder 7
Cylinder 8
You still see a hue of red...but its not like when new...
I hate to ask this but I have to. Did you check with a depth gauge or your eyeball? How about a fingernail check for protrusion?
AutoXRacer
Florida
No, I did not go into that detail. Just eye ball.
Wes06
Bahaha. If the coating is gone I will laugh because MMR sucks.
Sorry bout the problems your having though
AutoXRacer
Florida
No problems really, motor runs great.
But I would like to know why I'm down 4 psi.
thump_rrr
Montreal Qc,
can you please explain how you get your calculations?
