I'm working with my local speed shop on doing an N/A setup (decided not to go FI in the end). We were looking at doing a custom grind to put the meat of the gains in the midrage -- more for stoplight to stoplight than dragstrip. After waiting to hear back from the machine shop for 2 months, they finally say "Nah, what you should go with is Livernois Stage 2 cams".
I can't find shit on them either here or on the web. The shop says Livernois estimates them to gain 30-40 RWHP, but no testimony as to how they drive, the powerband, or how much lope they've got.
Anyone got experience w/ these?
I figure the lope will be pretty significant, going off the formula from the cam tech thread (Lope = (((Intake Duration + Exhaust duration )/ 4 )- lsa) x2 ). It comes out w/ a '8.5' which is slightly lower than the FRPP Hot Rod cams.
BTW, coincident mods will be Livernois valve springs, Comp Camps phasers, FRPP 62mm throttle body, FRPP high flow intake manifold, granatelli CAI, and JBA ceramic coated Long tubes w/ catted H-pipe.
I found it here and no one ripped it apart (S197 is usually really good about filtering out the bad info), so I think they'll be OK with it...
