46addict
13726548
I just read your entire thread. (Slow day at work.) I was super stoked when you got the third block together, and now I feel like my favorite super hero just died seeing this.
Coming back harder better stronger.
I like your decision on new pistons, rods checked and injectors checked. Now for the big question weight vs. strength...
Hell yea lolComing back harder better stronger.![]()
Man you have a great attitude towards this. Best of luck on the next build. I have learnt quite a bit from your posts, especially this thread and the ARP head studs
Boss block? why not the block? idk if they had a reason to not use it?
Yep, Soon as I get to speak with L&M I'll be able to make a better decision and which block to go with this time. I anticipate he will tell me to use the alum block again though.
Hell yea lol
It's all part of the experience, you know the sequence, something like build it, race it, break it, build it again! It sucks going through all the motors but I learn something new each time and can improve, and go a little faster and be a little stronger, hopefully.
They count the side bolt, not the side by side bolts, You'd need to drill and tap for the extra bolt pair ..
That is true on the count, but its not quite that simple though, there is a void under the main where the additional stud needs to go. You have to make custom mains for it. It also requires machining the block.
I saw your post about the blow by you were seeing and I'd surmise the rings lifted and dumped oil on that side.
That's why I'm having my aluminum block sleeved rather than use the Boss block, It'll be cheaper an easier in the end than machining the FRPP block ..
How much boost due you plan to run on it, and whos sleeves?
I'm planning a turbo build around a Turbonetics 7875, @20+, plus whatever spray it takes [likely 400hp worth] to trap 165+ to shutdown these stripped out grudge cars around here,, I'm tired of getting my ass kicked by em'.
The block has been sleeved with the Darton Coyote sleeves, the issue I'm having with it is the Cometic gasket was made for the iron Boss block and doesn't have the raised bosses around the water passages like the standard bore Cometic, the Coyote gasket also has the raised embossing so it seals .
I've talked to Cometic about getting a standard bore gasket cut out to 3.700" but they won't do it.
Soooo, the machine shop is pulling the sleeves, re-decking the block and going to reinstall the sleeve with .001" left above the block deck so that should allow the gasket to seal.
If that doesn't work I'll use a dremel and auger out a stock bore gasket myself. And if that still don't werk, we'll plug the passages and drill holes to match the gasket.
These Coyote sleeves will not move, they have a large lip that keeps them locked in place.
Cost was 950 for the sleeves, 750 to install.
Sleeves going in ..
Sorry for the thread jack .,.
Interesting, who is doing this machine work for you?
TKM Performance in Denton NC
Have you called Tim at MPR? He is in Boynton Beach Florida and will gladly get you situated. Don't have to ship your engine all over the country. He builds just as much reliable Horsepower on Mod Motors than anyone.
561-588-0188
