bunits19714
monroe , mi
Dropped the horse at the vet yesterday- rewind to July 6th after washing the car to get it ready for a street car race event at a semi local(100 miles away) track, I decided to get on it on the return way home and bam- snapped the end of the crank off. - On July 9th ordered new engine received it on the following Monday and have been gathering all the other parts needed to speed the process up- Was thinking of doing the L ands M intake cams and gen 2 heads this mid summer anyways, (before this happened) - Well NO GEN 2 heads to be HAD any where in the country(new)(the left one). so I decided to just run the stock 14 heads with the l and m intake and 15-17 exh. cams (12-13 boss) with new valve springs- Well get the call today after they got the motor out - broken cam tower(s) on the one head . broken follower, oil pan bent beyond use, broken front timing cover(which I knew) broken water pump & pulley as well- So at 4 pm today I am scrambling to find a set of heads.. finally found a set of 12-13 boss heads in stock(which is the key) at Livernois, will be picking them up in the am and driving them to the tuner/ assembler in Norwalk , OH- 3179$ versus gen 2 production for 1350$, I think I need my heart nitro and a few tums before I go to bed..
Livernois was very helpful and there boss heads are suppose to have a valve job and upgraded intake valves. and better springs- I shall see in the am.
EBABlacknChrome
Michigan
Ouch! Shit, and good luck! Sounds costly and maybe painful.
bunits19714
monroe , mi
both heads are junk broken cam towers on both sides- was told there was coolant in the engine oil as well- should get a pic after they pull the heads off- new heads look good- not as nice as the slawko ones setting on the bench next to my boss heads but definitely better than the gen1 on the broken motor. Livernois has 2 sets of these left if anyone is looking/quickly for a set of upgraded heads- lol. Gen 2 heads are no where to be found new or used-(ready to go)
travelers
Eastern Pa
You destroyed a set of Tommy Slawkos heads??? His place is about 30mins from my house and it's cleaner then a hospital. I've been in there.
And I have both of my keys....locked up......
bunits19714
monroe , mi
no, they were factory gen1's(2014) the new head is a boss casting with mild upgrades- on the bench at the tuners where I sat mine down there is a set of slawko's going on another engine on the stand next to mine- they looked like art work. If I would of destroyed a set of them I would of been slightly more upset-
travelers
Eastern Pa
He an artist when it comes to heads. I picked up a set of 426 hemi heads and they were better then any I've seen.
Maybe you should switch stands.....Lol
utlong31
I put a set of Brisk Plugs in it then washed it and went for a drive.
nyuk98GT
Infrequent poster
Chesterfield, MO
Put some FRPP rear bumpstops on the other day. The drive-to-work road test proves that the new stops are softer than the stockers and the thunk in the rear over a bump is quieter. Goldilocks would say the stops are 'just right'.
I figured out that the bumpstop screws are best accessed over the wheel rather than from underneath. Duh. Live and learn.
Chris
dark steed
Resident noob
Winder, GA
Did you have a bama tune in it before?
Yes, but it was about five or six years old. I heard such bad things about the new group there I wouldn’t update it. It didn’t run bad except for a little bucking when it was cold. There was a definite improvement with Lito tune, no bucking on the cold start and it hadn’t been ran into weeks. It pulls a lot harder throughout the power band, definitely more wheel spin in second gear!
06 T-RED S/C GT
Carnegie, PA
Went ahead and had the stock 3:55 ring and pinion gears reinstalled, as I didn't feel the need for 4:10 gear ratio with 5 spd manual and Saleen VI blower. Most of my driving is on the highway at cruising speeds anyhow and felt that gaining top end at 2000-2500 RPM was more important than gaining low end off the line quicker. At any rate, I'll be listing the 4:10 ring and pinion gears up for sale.
JG-1
Hainesport, NJ
Installed an SR Performance billet clutch extension. I thought it was going to be easy but it turned out to be a real pain in the ass.
