298 stroker build...which water pump and which limiters?
DiMora
More Is Better
Fayetteville, GA
As title states, which water pump should I buy?
I was just going to go OEM (M otorcraft PW496 ($79) but I see Edelbrock has their Victor series ($189) which has a bigger bearing and CNC-machined internal housing - and they claim it flows more.
American Muscle has an OPR branded one for $50 (possibly a reman OEM?)
I don't care about the cost, I just want a good one. Leaning toward the Edelbrock. I ask simply because sometimes OEM is best (coil-on-plugs come to mind).
Topic 2: I also have both Livernois and Comp phaser limiters. Which should I use? I've read bad things about both. Leaning toward Livernois.
Dino Dino Bambino
I have a red car
Cyprus
The OEM pump should be fine.
As for phaser limiters, the Comp versions are a single plate and aren't likely to fall out of position or fail as easily as the Livernois units, so I think the choice is a no-brainer.
DiMora
More Is Better
Fayetteville, GA
Did some more searching...found multiple threads with Livernois carnage. I'll stick with Comp unless someone has a good reason to convince me to go with Livernois that is safer than Comp...
Here was Tiger Honaker's failure:
sportinawoody
Piedmont area , N.C.
no such thing as a good limiter, lock them out or leave them alone. comp limiters made my car do some weird shit on the dyno so I just locked them out and problem solved
DiMora
More Is Better
Fayetteville, GA
I can’t leave them as I could have piston-to-valve contact.
I want to keep VCT intact somewhat; it does some good things down low.
I’ll do the Comps.
Aussie-Parnelli
Adelaide
Definitely don't use Livernois they are crap and do fail, as others have said. Mine is personal experience.
sportinawoody
all new phasers comes with a different spring and spring profile which is basically an added bolt adding pressure. came standard I believe on mid 07 -up cars
JeremyH
3V Fuel Guru
Virginia Beach
This. My 07 had them from factory. Were revised late 06 for mid 07 model year iirc. Change afaik was a better spring/pin design. Just one Ford part number for the new design 3R2Z-6A257-DA and can be used on either side. They have L and R timing marks 180 out which is a quick way to tell visually. Vice old versions had 2 part numbers one for each side with either a L or R and then a notch on the other side.
cavero
NoVA
How many miles and under what conditions do the Livernois fail? Mine have about 15k on them
DiMora
More Is Better
Fayetteville, GA
GREAT information; thank you!
I have a couple sets of phasers in the garage; I’ll have to see if I have any revised units.
