Supercharged 06 with FRPP Hot Rods...tired of the lope...alternatives?
06redgt
Oswego, Illinois
So I love the car...but not loving the off idle drivability of the FRPP hot rod cams. What other cams give good power with a Procharger that maintain a nice idle? Current setup is blower, cmdp's, long tubes, hot rods. The cams were installed a few years before the blower...if I knew what was coming I would have probably gone a different route!
I loved the choppy idle the hot rods gave me but now its growing old...or maybe I am haha.
AndrewNagle
Mountains of NC
Comp cams Detroit rockers
I had hot rod cams pre super charger kept them when I had the Paxton put on and than later changed to the Detroit rockers and the drive ability is night and day but they still sound lopey
Aerofinz
Mustang's Backyard
I get it OP, the "cool factor" with me is pretty much over too (FRPP cams). I'd rather just go fast vs. announcing to the world that I might be able to go fast, LOL!
But I admit I am getting old(er). My son-in-law LOVES the obnoxious sound.
Edit: that was until I saw "fdjizm" sig. Those numbers are only cams? No gear or any other upgrades? Impressive!
AndrewNagle
Mountains of NC
I've been looking at those...do you know how they compared power-wise to the Hot Rods?
I don't since when i switched to the Detroit rockers we also went to a smaller SC pulley
and they do sound good just not the same as Hot Rods
tjm73
of Omicron Persei 8
Rush, NY
The cost of a set of custom cams dialed in for your combo is almost the same money as a catalog grind set. I suspect you could get more power and less or no lope with a set of custom cams.
$740 for custom to your needs/wants. This is just a for instance. FTI is highly regarded but others do cams as well..
http://www.flowtechinduction.com/fti-custom-roller-camshaft-3v-ford/
I guess I'm getting old too. Some cars just need that lope, but I find more and more that I really like the "stealth" setup that looks like a nice clean car that makes little noise but is like a bomb went off when the time comes. SURPRISE!!!!
eighty6gt
I have Comp 127300's I got used
they lope a little bit, drive like stock, monstrous power, stock phasers.
Dino Dino Bambino
I have a red car
Cyprus
He does actually have an impressive list of upgrades:
Engine:
C&L Racer Intake
CMCV Delete plates
Pypes long tubes & Off road X-pipe
FRPP Hot rod cams
Steeda underdrive pullies
Prothane billet motor mounts
WOTBOX
Exhaust:
Pypes m80 mid mufflers
SVE axle back mufflers
Suspension:
BBR billet LCAs
J&M adjustable UCA
BMR UCA mount
BMR LCA relocation brackets
Strange adjustable struts/shocks
Bullitt springs
Adjustable panhard bar
Panhard bar relocation bracket
Front swaybar delete/radiator support
CHE k-member brace & torque limiters
Prothane rear differential bushing
Drivetrain:
T56 Magnum XL (Just added - no new personal best, yet)
4.30 gears (Just added - no new personal best, yet)
Strange 8.8" Lightened Spool
3.5" aluminum DS
T&A differential cover
Exedy Mach400 clutch
Strange 31 spline axles
SLP Line Lock
Wheels/tires:
Hawk HPS brake pads
15x8 sportstar rear
Hoosier QTP 26x11.5x15
15x4 sportstar front
Nankang cx668 165/80-15
fdjizm
Drag Queen
Shieeet don't be putting my business out in the street.
K&N Drop in filter and THATS IT!
I did it to make fun of the Chebby guys with their "cam only" line.
Dino Dino Bambino
I have a red car
Cyprus
Well, it looks like a throttle body spacer is next on my mod list. What's it worth? 70rwhp? ;) Should be enough to land me an 11-sec timeslip. :D
Sactown
Sactown
Sacramento, CA
Comp Cams 127350 they require springs... but excellent drive-ability, good idle, nice power curve. Actually still using running them even with the turbo, and yes I know they are the "wrong" cams for a turbo.
MrAwesome987
Upstate SC
I have the Brenspeed Detroit Rockers SC cams in my car. The car is currently NA, but it drives pretty much like stock but feels a good bit stronger over 3800 rpm. It has a tad bit of lugging in parking lots if you are just letting it idle around, but its never been a problem for me. They sound great too.
Edit: And they don't require springs or lock outs.
