I have read this forum multiple times and it has tons of useful information ,
I have a 06 gt Auto, I am swapping 6r80 from 11 f150 4x2 5.0. I had a few questions I am not clear on.
Am I ok with keeping the stock Auto ECM or should I swap for a Manual? Will I get check engine lights with auto?
I am not clear on the transmission lines, will 2006 trans lines work, will 2011 trans lines fit 2006 radiator? or should I run a seperate cooler?
How is the stock converter? I was thinking of updgrading but seems like a lot $$.
is the swap really worth it, did you notice that much difference?
My parts list, am I missing anything?
Trans 6r8o BL3P-7000-AA or AB
cross member BR3Z-6A023-B trans mount BR3Z
drive shaft - Aluminum aftermarket.
Quick 6
11 mustang shifter BR3Z-7210-AD with cable BR3Z-7E395-C , 13 handle DR3Z-7213-BA
cable mount bracket PA68502
11 flexplate BL3Z6375A
Autometer tach signal 9117
thanks
