Joe combs
Stacked more parts on the pile of parts to be installed(gathering parts for a whipple 2.3 install).
Damn! That sounds like a tough year long project. I’m prepping to freshen up my engine over the winter and I sure hope it goes smoother than that. Fortunately I can do most of the work myself.FINALLY
That looks like a great way to prevent tanglefoot when dataloging.Now off to start running VCM Scanner datalogs!
I need to look closer at this. It is so difficult to do datalog pulls at 6'1", 330 lbs, with a size 15. Where did you pick up the plug?Just got my new Dummy OBDII Relocation harness installed so I can now perform driving datalogs w\o OBDII interface interference whatsoever:
View attachment 84880 View attachment 84881
Makes for a clean plug & play install wiring-wise.......no cutting or splicing needed, all excess cabling is tied up neatly under dash. To mount the relocated OBDII port on passenger side I had to make a special bracket out of some aluminum flat plate to keep the port tucked close under the dash (the normal L-shaped OBDII relocation port brackets allow the port to stick too far down below the dash line for my tastes)
View attachment 84882 View attachment 84883
& out of the way for passenger leg room then mount it all using some M6 x 20mm black anodized license plate bolts w\ black trim bolt head covers to give it a more custom look & got a black OBDII port cover to hide the pins so it all blends into the black (dark) background.
Tested all out.......all working as advertised. The fake OBDII port will power up any OBDII tool\interface attached to it but will not allow any connection to vehicle's DLC system (tool just searches for protocols to no avail) while the relocated real OBDII port operates normally.
When getting into car normally on passenger side, this relocated OBDII port is not visible thru normal line of sight........
Another reason why I went w\ this setup....in addition to not hitting the OBDII interface w\ my left knee while operating the clutch, having to rig up\rig down clearing the shifter\steering wheel, etc. A plug & play 1 & done install........no cutting, splicing of any wiring\ports & ain't gotta mess w\ it anymore once installed so it's always there to use when you need it. All located on the passenger side so laptop can sit in passenger seat so I can use my 12v outlet socket inside console storage to power laptop......keeping the driver side & console completely clear of cabling\obstructions thus free to navigate. The dummy OBDII port was extra.......wasn't looking for\needing it but it comes w\ this harness. Has a tangible purpose so it's not a total waste & maintains the full OEM interior look.That looks like a great way to prevent tanglefoot when dataloging.
Here is the web site:I need to look closer at this. It is so difficult to do datalog pulls at 6'1", 330 lbs, with a size 15. Where did you pick up the plug?
Thank you
Thanks!All went excellent. 1st thing out the gate.......this APP ain't got no flat spots in the signal generation off the at-rest position.......I swear if you breathe on the damn thing the engine will respond! And I LOVE IT.........makes driving a manual trans using a hydraulic clutch w\ DBW throttle control much, much easier to time clutch engagements to engine response w\o flaring the engine RPM's.
FYI.......................
Hi Griffx,Thanks!
Most annoying with the manual trans is that I have to lift the APP 2/10 second before I press the clutch to avoid an engine rev-up. Has this changed too?
Ok...........I'll look into this on my end & will post back what I find out.Right. On all my other cars I lift the gas pedal and press the clutch almost simultaneously. But not on the S197 (and also on the S550). If I want to shift at e.g. 2000 UPM, lift the gas and press the clutch in parallel, engine revs up to 2500. So I have to lift the pedal 2 10th earlier than pressing the clutch. It is like the lag when you press the gas pedal, but inverse.
I tried today what you've posted here w\ my car & sure enough, she did exactly what you said it would do.Right. On all my other cars I lift the gas pedal and press the clutch almost simultaneously. But not on the S197 (and also on the S550). If I want to shift at e.g. 2000 UPM, lift the gas and press the clutch in parallel, engine revs up to 2500. So I have to lift the pedal 2 10th earlier than pressing the clutch. It is like the lag when you press the gas pedal, but inverse.
Thanks! So I know it's a programming issue. I guess I noticed this because all my other cars do not behave like this. In general, it looks like the ECU is not really optimized for manual transmissions.I tried today what you've posted here w\ my car & sure enough, she did exactly what you said it would do.
But TBH, I had to really force myself to actually hold the APP slightly depressed while depressing the clutch.............guess I've always timed my coordination between clutch & throttle to be fully off APP at the moment I was depressing the clutch in, so I never ran into this scenario in times past before your mentioning of this..........
When I reverted back to my usual habit of working the APP w\ clutch I never had this happen again, so I guess my normal driving habit w\ my manual Stang is releasing the APP the 2\10 sec before depressing the clutch when up\down shifting........explains why I've never had this happen in times past.
Don't know how this helps you out but I see\understand now where you're coming from.
As long as you performed the initial KOEO APP calibration procedure, you should be good to go (there's no section in any of these '05-'10 SO PCM tune files to calibrate an APP........the PCM automatically does this on every KOEO). As for the MIL light thing, this may just be a feature that your '05 GT SO PCM's calibration may not have (appears starting in the '08 MY thru '10 MY, Ford made some changes\enhancements in these GT SO PCM's base calibrations that do not exist in the earlier '05-'07 GT SO PCM calibrations......the KOEO self-check MIL light signaling may be 1 of them.......I had to stop using all OEM '05-'07 SO PCM tune files as references after finding this out & only use '08-'10 SO PCM tune files for referencing w\ my '09 SO PCM as some of the setup\settings are different) & my '09 SO PCM's calibration has (this occurred after my KS harness\CMCV actuator\position sensor reinstall.......when I replaced my APP--did this prior KS replace\CMCV actuator\position sensor reinstall job--& ran the KOEO APP calibration my MIL light did not flash either).I did the calibration procedure, but a no time was I able to get the CEL to flash. Maybe the tune is interfering, will try again tomorrow.
