The AZ ones are okay for installing a new O2 sensor, but from my experence, they don't work well on a really tight one that is cold (ambient temp).
I should try warming the engine up first. Might work then.
My dealer is 229.00 per hour. Alldata shows it at .6. We would be at 137.40Can't get an O2 sensor socket from Autozone?
Kroil was sent from God.Be sure to usa Kroil. And heat the bung up with a mapp gas torch instead of firing the engine up, it would be a hand and arm burner otherwise.
Success!Be sure to usa Kroil. And heat the bung up with a mapp gas torch instead of firing the engine up, it would be a hand and arm burner otherwise.
Tell me about it! Kids are worthless...just try getting one to install a timing kit on a 3v....better off doing it yourself and save the Animal Crackers."Bled" the brakes with the kids... when I say bled I mean I did it alone with them watching and telling me when the bubbles stopped. While they're definitely better than they were before they still don't feel good, I guess a 5 year old may not be the best brake inspector..
Such a great review without pictures?!Finally broke down & ordered a full set of WeatherTech molded floor mats in matted black that fit 05-09 S197's to replace the original black rubber Mustang GT mats I had bought from CJ Pony Parts right after I bought the car back in 10-2017 (had worn thru the top section of the driver side floor mat thus it had split from the rest of the mat).
Installed them after 1st cleaning up the carpet...............after getting them all installed, now I'm kicking myself for not getting these from the jump. The fit is so tight to the floor pan area & the color almost seems to blend into the carpet--also I can now see just how much easier it's gonna be to clean her up going forward w\o needing to remove the mats--just as advertised.
Took several attempts to resize them so that they will actually download to the forum....................finally paid attention to the .jpg pixel sizing that the forums will now accept so going forward this'll get easier. Note: the resizing ruined a lot of the actual picture resolution\quality that my IPhone 15 is capable of, thus doesn't show the much cleaner look that you'd be seeing in RL............Such a great review without pictures?!
I've had mine for...8 or 9 years and love them. I was going to get the trunk liner, but I have the Shaker subs, so they won't fit.Finally broke down & ordered a full set of WeatherTech molded floor mats in matted black that fit 05-09 S197's to replace the original black rubber Mustang GT mats I had bought from CJ Pony Parts right after I bought the car back in 10-2017 (had worn thru the top section of the driver side floor mat thus it had split from the rest of the mat).
They look great! I might have to get a set myself!Took several attempts to resize them so that they will actually download to the forum....................finally paid attention to the .jpg pixel sizing that the forums will now accept so going forward this'll get easier. Note: the resizing ruined a lot of the actual picture resolution\quality that my IPhone 15 is capable of, thus doesn't show the much cleaner look that you'd be seeing in RL............
Had originally looked into LasFit molded floor mats (same type design.........different brand) but they only make them for S550-S650 (2015-2026) so had to fall back on the OG--WeatherTech--as they make these for our older 05-14 S197's..........
Here ya go!
I was tempted to get it as well, but I already have a custom black trunk liner w\ "GT" embossed in the center installed (bought the same time as the original rubber Mustang floor mats from CJ Pony Parts.....) that is made from the same carpet materials as the interior floor carpet thus stuff I put in the trunk doesn't tend to excessively slide around, so I passed it up.I was going to get the trunk liner
