bigray327
Awesome, thanks much.EDIT: Here's the driver I found that works with the black cable
http://www.kinamax.com/drivers/SBT-USCXX.zip
Well I couldn't powershift 1-2 before if there was a gun to my head, now it slips in like butter, you don't get any resistance when shifting.I wasn't feeling the need to go through all 5 pages.
I am wondering if anyone has any real world results while racing? Any feedback would be nice.
I can't get the software to see the box, even with the drivers posted above. Annoying. I'm about to fire off a nastygram to the people at N2MB. The year is 2010; they should be able to make software that works on freaking Windows XP.I got my software & drivers working - I'm able to hook up my laptop to make adjustments to the default settings.
Mine worked fine on XP on my laptop if you go into the device manager it should show you what com port it's on... also now since the drivers installed it doesn't make the "usb sound" but it's there on com port 5 on my laptop every time I plug it in.I can't get the software to see the box, even with the drivers posted above. Annoying. I'm about to fire off a nastygram to the people at N2MB. The year is 2010; they should be able to make software that works on freaking Windows XP.
I did all that, and set it to the correct port... no luck. I'll figure it out, eventually. Luckily, the default settings (auto on the shifting and 4000 RPMs on the 2-step) might be what I want right now.Mine worked fine on XP on my laptop if you go into the device manager it should show you what com port it's on... also now since the drivers installed it doesn't make the "usb sound" but it's there on com port 5 on my laptop every time I plug it in.
under device manager look under 'ports'
Rebooted a couple of times, no joy. I must have a bad USB/serial cable. Annoying.Hrm...I'm using it on Windows XP. Did you reboot the laptop? I know it took one or 2 reboots until it worked for me.
Next topic: didn't someone say that you can hook up a shift light to this thing, somehow? I'm getting the same problem that someone else mentioned earlier... the shift light (connected to a coil wire) lights up after the clutch pedal has already been stomped on.
That sucks. I figured you could connect an aftermarket shift light to it, somehow (maybe through the serial port), not actually use it as the light. That thing isn't pretty... no way it's getting mounted on my dashboard. It currently lives in my glove compartment.Yeah Ray... that was me. It SEEMS that the WOTbox itself is a "shift light" - notice the parameters can be set just under the Rev Limiter in the screenshot fdjizm posted? If that truly works... I plan to just disconnect my Raptor shift light & sell it.
Now we're gettin somewhere.For the shift light all you do is use any led bulb and tap into a wire on the wotbox for your positive, and that is your new shift light after you activate the feature.
you don't have to have the actual box as the shift light.
Which wire? Am I missing shift light installation in the instructions?
