Right now, what my car has done to it is pypes shorties, pypes orx, mangapack CB, and a C&L intake.
I have plans in the future to do a 2.6 KB. Those are expensive, so I was thinking for now to do all the supporting mods minus the blower and drive the car like that until I have the money for a blower.
What I was thinking is...blower cams, 3.73s, motion plate deletes, LT's, and a tune.
Would the car run with the blower cams ok even without the blower?
Thanks Guys!
Not sure what you have as other mods, but take this for what it's worth:
First thing to go for me after the KB 2.6 install:
Stock clutch slipped, had to swap out clutch/flywheel/tob
Stock drive shaft started hitting under side of car, had to go one piece and adjustable LCA's to set pinion
rear end sagged on launch, needed relocation brackets
stock tires too skinny, needed bigger/wider rims and much better tires
brakes couldn't handle the extra speed, needed new brake pads, and I got new stainless lines and Stoptech rotors as well.
Do not get the charge motion delete plates, when you put on the kit, you get rid of them anyway.
I would skip the blower cams, there are other things you will need that will keep you safer (tires and brakes) and if your stock clutch is slipping with the KB, the extra HP the cams will give you will only make the slipping worse.
If you have an intake, you should already have a tune. If not, get that first, since you are probably running lean, which is bad.
But really, a KB kit with a 8psi pulley will still get you 472 at the wheel on a cold night (mine does), and a 10psi pulley will definitely get you there. With a good tune, you should be able to stay safe and happy at 450rwhp until you can save up and go built and then you'll need more fuel, better tranny, etc.
The KB kit comes with a KB Boost a pump. Mine has been working fine, but some have saved up for better options, GT500 pumps, etc.
If you get the KB "tuner" kit, you will have to supply your own tuner, injectors and MAF. I went this route since I already had and XCAL II and I got the injectors cheap off of ebay and the 90mm Lightning MAF cheap off of a Ford parts website.
3.73's would be nice, but you don't really "need" them. I still have 3.55's and they are fine, still loose all kind of traction without drag radials.
Long tubes, just not sure they are worth the $1000 plus/minus investment. Put that money towards the KB because once you have it on, long tubes or not, you're going to be at the limit of the stock block and if you want to go higher, you're going to have to go built.
