6.2 swap in an 08 gt
killr3v
Hector G.
Katy, TX
shame these engines arent at least 3vs but im not real sure on the specs of these heads... the past 2v heads were boat anchors lol. my vorteched 02 2v gt only put down 50rwhp more then my n/a 08 3v... looking forward to the payoff drive to this surgery
These new heads are so much better it's unbelievable. Just wait and see...
Germeezy3
Have you ever driven a 5.4 3V F150? The 6.2 2V kills that engine!
f250 base motor is this engine also....
Yes but different cams and only 385 hp.
wow, nice. Sorry for the newb question but what did this motor come out of? or was it just built? I know the new raptor svt has a 6.2L :)
Same motor as the Raptor...
yup there big Valves with a Dual spark plugs
I don't think they realize how much better these dual spark heads are, thats were the power came from as much as the displacement increase.
06silverbullet
orange county, ca
i'm interested as too see how the 6.2 will respond to mods. it puts out the same power as the 5.0 4v stock vs stock. i wonder if the cubes in the long run will make it the better choice or not.
Germeezy3
Torque is what the 6.2 was built for and 434 lb ft a better power curve, and more power under the curve are all good things. The only time cubes is a bad thing is if your the EPA, or your in a spec race series.
06silverbullet
orange county, ca
yeah but the limiting factor i think is the 2v heads vs the 5.0's 4v heads which i think will help over come which so far they have the lower displacement vs the chevy and dodge motors.
Anthony05GT
Maryland
Not trying to shake things up to much, BUT!!! I have been working on a twin screw blower intake manifold for several months which is nearly finished. With the accessory drive 5" farther forward, there is a problem with the slope of the hood and the blower pulley wanting to occupy the same space.
On that deal it looks like you have a couple of choices...try to lower the engine or cut a hole and fab up a one off scoop of some sort to cover the protruding snout. Sounds like another opportunity to me.
j95svt
Hey guys, I have been reading on this forum for several months and saw this thread and had to post.
These are not your average inline valve 2v heads they more closely resemble the dodge hemi with the intake valve on the intake side of the head and exhaust valve on the exhaust side of the head. Huge 2.10 intake and 1.65 exhaust valves will allow this engine to breath.
Don Bowles posted a 9.10 @145 in the 1/4 using a n/a 7.0l version of this engine when it was in its experimental form.
Germeezy3
I remember reading about that, they never even told him what the motor was initially! Ford also built a 7.5 liter version of this engine for off road racing. I don't think anyone realizes that they are looking at the holy grail of modern Ford engines here. A small block that will go up to 460 cubes with good heads, this thing is the modern day Cammer!
fhlh
Grabber? Don't Know Her!
Houston
This Motor stroked to 427, 428 , or 429 would make an awesome Mustang engine! I would love to put 427 Cammer on the side of our project car!
a modern "Boss 429" sounds saucy!
it's a 400+ HP motor from the factory.... it can be punched out to 460+ cubes. I think Roush had/has one in N/A form making over 600hp.
pacettr
PJ Lover
Yukon, OK
It will be interesting to see if this makes much if any more power than a built 5.0. Subscribing for sure.
Kraftsman
Schoolcraft, MI
Count me in, subscribed. What trans are you planning on using? Is the bellhousing bolt pattern the same?
Sent from my ADR6300 using Tapatalk
Germeezy3
N/A
06silverbullet
orange county, ca
what kinda compression do those motors run?
Germeezy3
Yes I know. What will a bored/stroked/worked 5.0 do in the same application?
The biggest I have seen a 5.0 go is 351 cubes and thats with a lot of stroke. The big bore 6.2 is a much better way to start for a big cube build.
RED09GT
Equal Opportunity Offender
Kelowna, B.C. Canada
A cam change alone on these motors is going to be killer. From another site, head flow was suggested as being north of 300cfm on the intake side and 200cfm on the exhaust side, couple this with a bore that will let it breathe and this will be big.
My 393w in my 82 GT had AFR 205's, which flow a similar amount, coupled with a 4.03" bore, and a heavy hydraulic roller valvetrain and a rather mild cam. It made 453rwhp at 5900 rpms. Now take the 6.2 which isn't much smaller (379 cu inches versus 393) and it's valvetrain that has the stability and potential to rev past 8000 rpms. As great as the new 5.0 is, the potential of this motor exceeds it. Hopefully that potential gets realized.
