GrnBullitt08
Dale Jr
Yeah I hear ya... The 4.56s are pretty extreme for highway use.
Changing it up a little bit
On my black drag rims I will actually be going to a smaller tire... 26x10 MT stiff side wall slick (pure street style tire) so it will be smaller overall Dia (even more gearing) then my old 28x10.5's
On my polished bogarts I currently run a 275/60/15 MT Street radial on the street.... once I wear those out I think 325/50/15's are in order to hook even better on the street
I need to run 28's on the street to keep the rpms a bit lower on the hwy![]()
They must be a lot cooler there about street racing... lol Please tell me you can hang the hoops leaving a light on the street... I've always wanted to do that. hahaaa
full suspension travel front end comes up but not lifting... I launch it about 3-3500 slip on the clutch sorta quick and it grabs. I roll 12lbs of air in the rear drag radials on the street all the time lolYou just can't win with this cage
Seems that way -_- lol.... If I didn't need one I wouldn't put one trust me... I did run last eyar without it pushing it at the local track. But Im not going to spend all this time and money making everything super light then add more weight then I really have to with the cage. It weighs 85-90 lbs should be about 60 the moly one.
I accounted for the 60 lb gain onto the car not over 80 lol
I might sound crazy but every lb is counting at this point
do you mind posting a pic?
I think they look bad ass in there... very happy they fit nice
Here is the pic you wanted Matt.... I still need to do something with the center of the cluster
What size are those gauges and how do you get the speedometer to work?
Sick!!!! The speedo has the connection to go to the trans sensor correct?
I have my shift light that will be in the middle , Also I have some small sheets of carbon fiber that im going to mock up so sit as a background. Will match the carbon gauges.
Im very excited to finally use my big tach with play back... I want to be right on the money with everyshift
