BOSS Intake on Modded Auto
Livernois Motorsports
Dearborn Heights, MI
Our dyno results were similar to others I've found online. They seem to lose power down low, but carry the power out much further up top. The graph below was a test on our auto car with a stock intake vs. the BOSS. We saw a gain of 59 RWHP at 7,400 RPM's. I have a feeling cams are going to make some good power on this car.
Mods are:
Livernois Motorsports 12:1 Pistons
Livernois Motorsports Stage 1 CNC Heads (Stock Cams)
BOSS Manifold
Stainless Works Headers, Catted Mid-Pipe, and Catback
CAI
4.10 Ring & Pinion
Circle D Stall Converter
Livernois Motorsports 1-Piece Aluminum Driveshaft
Livernois Motorsports Dyno Tune
FRPP Springs & Adjustable Shocks/Struts
Drag Radials/Skinnies
:clap:
Regards,
Rick LeBlanc
Full_Tilt
Nice work!
I look forward to seeing what the difference is in the quarter.
302
Atlanta GA
Can't really see the chart, or my eyes aren't what they used to be. Congrats.
Intervention
Our car has stock cams and springs and I have over 120 track passes and 50 dyno pulls with it shifting at 7,800.
-Rick
Cant complain with that. Any words on power gains from the CNC'd heads? I am looking to keep mine NA and possibly due heads and cams in the future
302
Atlanta GA
Wow, it definitely displays blurry. Stock intake numbers were 428/393 and BOSS intake numbers were 441/379. At 7,400 rpm's it was up 59 RWHP / 39 RWTQ.
-Rick
Thanks, i could tell there was a gain but really did not know what they were.
I'm not sure you'll see much with just heads on a N/A application. Our car has ported heads, but also has more compression. It really needs a set of cams. We've been pretty busy, but hope to get a stock 5.0 on the engine dyno and do different tests like that soon.
-Rick
Intervention
-Rick
That sounds fantastic. I might skip the heads then, and go straight to cams as soon as they are available.
Cams with the Boss 302 intake manifold sounds to be a great combination!
I loved seeing your white track car at my local track(NED). I personally saw it race the red Z06 and took video as well. What a race
Full_Tilt
The power was nearly identical to the power it made with the prototype manifold that was on it. Best ET was 10.89 @ 123 mph at full weight minus tire and jack and wheels/tires.
-Rick
Did you ever run it with the Stock Manifold, all other modifications being the same?
