Aluminator going in, need some opinions
onebad95
New hampshire
Well, dropping the car off tomorrow to start the swap. I would like to know what head gaskets you guys recommend?
tbrock
colorado
I am following as this is something I want to do. I'll be curious about the final cost.
JeremyH
3V Fuel Guru
Virginia Beach
Yes you will want a new pump but you will also need billet gears, above 500rwhp its no a question of if, its a question of when, the oil pump will go.
JoshK
Modder AKA Fuel
Nebraska
Great info guys. One question though, I have seen the aluminator with like a 8.8CR and the stock CR. Do they make one somewhere in between or would I be okay with stock CR on my car(only want to be safe around 600). I found a company on ebay that sells this engine for $3500 shipped which seems like a good deal to me?
JeremyH
3V Fuel Guru
Virginia Beach
To my knowledge those are the only 2 pistons compressions they offer. You could always get different psitons if you wanted something different.
Both those compressions will make similar power with a turbo. With the 8.8 you would just need to run probably one more lb of boost to make up for the 20rwhp you loose dropping compresison a point. 8.8 will of course be safer for a street car. Either setup would be fine on 93 octane for 600rwhp though.
