tigerhonaker
Gerald,
Man you do excellent pics buddy.
It all looks great !!!
Terry
Terry
Looking at the rust on the top of the crack, I'd say it's been cracked for a little while.
You don't need the front sway bar to drag race. Most unhook or remove it for better weight transfer anyway. Go drag race!
I won't do that... I'm not a pro-drag racer. I just to it for fun and an opportunity to open her up without going to jail. lol
You think its the drag racing breaking the support?
IF you toss the front sway bar, your handling could easily get worse for street use.
What size DR's are you using.. how wide and what width rim?
Another option might be 11.5" wide forgestars on the rear...with 315 mm wide nitto invo's..and the requisite offset of course. I think the invo's have a 200-220 tread wear rating. Then use a 285 or 295 front tire.
Now that's customer service! I wish more vendors took such good care of their customers.
Yes - you definitely have our full catalog under that car.
As for this part - we literally started the new design process about 30 mins after you sent us your first broken piece. We started analysis on your part - and before we even concluded what the issue was - it was apparent that it didn't matter, simply because it should not happen. That is why the new design is so robust - regardless of weld quality, material quality, etc....I don't want to see the mount just come off. With the new design, even a cracked / compromised tube/weld...and the mount likely won't fall off.
I am going to send it out today for you.
Thanks for the words.
What about the rest of us with the BMR K member, do we just wait for ours to break and you will send us a new one or what?
