3V TT kit from S&H Performance
CraigNnem
What are the pros and cons to the single kit vs the twin kit?
Hopefully by the time this kit comes out I can have my running hot issue sorted out and make a decision on which one I want.
Im Definitely getting one of these.
Both setups work and have pros and cons, some people just like twins. ;) lol
Twin setup will support more horsepower on less backpressure with two turbo's sharing the load while allowing them to be smaller.(engine can breathe better) Tend to be produce more midrange tq with tq coming on harder and more peak hp (depends on setup design). Idea for a V style motor since it seperates the banks and doesn't force a merge prior to the turbo which tends to create more backpressure and heat pre turbo.
Twin setups will spool a little slower than a properly sized single, but we can taylor the turbo size(s) and ar to your goals when you order as well. Automatics will tend to like the twins better.
stang67
ohio
What I have is a 91 foxbody I have a coyote engine and looking to turbo it but there are no kits for it
stang67
ohio
When I get some of the other issues done then I will do that kinda hoping they get the 6r80 stand alone done soon
Dillon Dollar
oklahoma
Bobby there is a group buy on rhe l&m throttle bodies you should get in on the deal its in the classfields
Sent from my SPH-L900 using Tapatalk
Bobby
turbo gt about to go fast
Here is a pic of the intercooler/raid bracket with swaybar attachments on the car. After getting it on the car he saw he needed to lower the sway bay just a little to make it easier to get the oil filter iff so he is doing that now but you can see how it works. It looks bad ass
i am ryan
Nashville, TN
Awesome that you're making it work with the front sway bar. I though I'd read earlier in the thread that that wasn't a possibility. Or am I losing my mind?
Also, SHEET METAL INTAKE?!
