tmcolegr
It's All About the Build
Thanks for the heads up
See that nice, little plastic bolt thingy on the motor housing?
I've looked through the pics, where is it at?
I beleive he is talking about the picture looking straight down on the new FRPP Tb, on the right hand side, has some blue paint on it. some sort of adjustment set screw they set at the factory for the TPS (i think).
What else is left?
The assembly process continues.....
GT 500 oil pump 7R3Z-6600-AA (superseeded by 9R3Z-6600-A) has been installed. Pump was fitted with TSS (TSSM20) billet oil pump gear. Mounting bolts torqued to 89 in. lbs.
Windage tray installed. Nuts and pickup tube spacer torqued to 18 ft. lbs.
Oil pump pickup tube installed with o-ring in place. Pickup tube to oil pump mounting bolts torqued to 89 in. lbs. Support bolt torqued to 18 ft. lbs.
