TWIN TURBO build sheet
Here is a partial list of what has been done to the TWIN TERROR.....
More to come. Tell me what you think comments welcomed. Thanks
[FONT="]TWIN TERROR[/FONT]
MOTOR
2005 Ford 4.6Aluminum Block
[FONT="]Livernois STAGE 3 heads [/FONT][FONT="]5 axis CNC machined, valves, [/FONT]
[FONT="] Intake flow rate 300 CFM - Exhaust flow rate 215 CFM
1mm oversize (35mm) intake - 1mm oversize (38.5mm) exhaust valves, [/FONT]
[FONT="]Livernois VCT Lockouts[/FONT]
[FONT="]Crower Cams stage 2 [/FONT]
[FONT="]Felpro Head gaskets[/FONT]
[FONT="]Ford V10 Flex plate[/FONT]
[FONT="]04 Cobra Crank [/FONT]
[FONT="]Manley Pro Series Rods w/ L19 bolts - 9.0 to 1 [/FONT]
[FONT="]APR/SP2000 Head Studs[/FONT]
[FONT="]APR Main Studs[/FONT]
[FONT="]Steeda CMDP Deletes[/FONT]
[FONT="]Main Bearings[/FONT]
[FONT="]Rod Bearings[/FONT]
[FONT="]New Lifters, Oil pump, rear main seal, [/FONT]
[FONT="]New Ford Timing Chain, tentioners and guides[/FONT]
[FONT="]Brisk -2 colder[/FONT][FONT="]spark plugs[/FONT]
CUSTOM TURBO SET UP
[FONT="]TURBOS - TWO (2) GTR3582R Garrett [/FONT]
[FONT="]Headers-Stainless steel stepped 1-5/8” to 1-3/4” [/FONT]
[FONT="]Header flange tapered ½’ thick[/FONT]
[FONT="]Down pipes Custom Stainless steel 2-1’2”[/FONT]
[FONT="]2- 38 mm Tial Waste gates[/FONT]
[FONT="]1- Tail Blow off valve[/FONT]
[FONT="]V-Clamps Stainless steel[/FONT]
[FONT="]Hose Clamps Stainless Steel[/FONT]
[FONT="]Silicon Hoses High Temp[/FONT]
[FONT="]Custom Air to Air Inter-cooler custom made **flow rated @ 1300 cfm[/FONT]
[FONT="] Inter-cooler Set up 3” & 4” tubing[/FONT]
FUEL SYSTEM Custom RETURN STYLE
[FONT="]Fore Precision Triple Pump & Fuel blocks[/FONT]
[FONT="]100micron fuel filter[/FONT]
[FONT="]Walberg fuel pumps (3)[/FONT]
[FONT="]Metco Fuel rail[/FONT]
[FONT="]60# Ford Injectors[/FONT]
[FONT="]Lines are ALL Aeroquip & braided steel [/FONT]
SPEED SERVICE
[FONT="]Bore block 20 over with torque plate[/FONT]
[FONT="]Install main studs and line hone with torque plates[/FONT]
[FONT="]Surface block deck [/FONT]
[FONT="]Cut 10/10 & polish cobra crank[/FONT]
SUSPENSION front
[FONT="]BMR Tubular K-Member[/FONT]
[FONT="]BMR Upper control arms[/FONT]
[FONT="]Steeda Radiator Support[/FONT]
SUSPENSION rear
[FONT="]Metco Drive shaft safety loop[/FONT]
[FONT="]Heavy Duty Upper Control Arm Bracket[/FONT]
[FONT="]Upper adjustable Control Arm[/FONT]
[FONT="]Control arm relocation brackets[/FONT]
[FONT="]Adjustable Lower Control arms[/FONT]
[FONT="]Differential Bushing[/FONT]
[FONT="]Adjustable pan hard bar[/FONT]
Coming soon… S&S Chassis Custom built 8.8 rear end
Shortened 1.5” per side, re-welded and gusseted
STRANGE c-clip eliminators Basically everything Strange has for a 8.8
New coil over
TRANSMISSION
TCI Super Street Fighter Transmission
3500 rpm torque converter
TCI shifter
1pc aluminum driveshaft
[FONT="]Custom Fab oil pan and oil pick up[/FONT]
[FONT="]Windage tray[/FONT]
[FONT="]TCI 3200 [/FONT]
[FONT="]Remote trans oil cooler[/FONT]
EXTERIOR
[FONT="]Steeda Side Window louvers[/FONT]
[FONT="]CDC Hood Scoop with built in turn signals[/FONT]
[FONT="]CDC Chin spoiler[/FONT]
[FONT="]Sequential tail lights[/FONT]
[FONT="]Rear gas cap and lock removed and smoothed[/FONT]
[FONT="]Black Chrome mess grill upper and lower[/FONT]
[FONT="]Hood Struts[/FONT]
[FONT="]Clear front signals[/FONT]
[FONT="]WHEELS & TIRES[/FONT]
[FONT="]Godspeed 5" lip Black spoke with polished rim[/FONT]
[FONT="]18x10 rear 18x9 front[/FONT]
[FONT="]REAR tire
MICKEY THOMPSON 305/50/18 ET STREET RADIAL
Rear is lowered 1 inch[/FONT]
[FONT="]FRONT tire
18x9 General Exclaim UHP 255/40ZR18
front stock ride height
[/FONT]
