5R55S BUILDER level10,, Larry's, or circle D
GB10
8s coming soon?
Burleson, TX
remember, Travis isnt tuning anymore. He hired a guy named Andy and does the tuning there now and he is good to go.
Travis did my tune on my car after the L/T's and Hot Rod cams and the car drove great...but i would say it was 95%.
After i got my delete plates on i had it retuned. This time Andy did it and the car is perfect.
both HPP and Gearheads are reputable shops.
Andy is no longer working there. Travis is doing all of the tuning again. Apparently Travis had some issues with Andy's customer service skills.
Mojave Dave
You mentioned CircleD. They built my trans that I ran almost all year in NMRA Super Stang and it is great. Tuned by Triangle Speed, but that is too far away. I also have used Brenspeed and they are great. Good luck.
Shades
New York
I'm throwing PTC into the mix. I'm buying all my parts from them to build my 5r55s and their prices and customer service so far are excellent. If you would like to have them price some parts out for you PM Chris06GT (a member on this forum). He works for them.
INTRUDER
Installation is not a problem.
What i want is to BUY a built 5r55 trans. and 3500 rpm torque converter.
Tuning is another question, I feel confident in both Brenspeed and Livernois as tuners.
Both have run and built very fast cars.
IF? IF? anything I am leaning towards Livernois just because they have run WICKED quick cars with turbos.
Shades
New York
What I want is your opinion on which trans builder makes the best/strongest 5r55s trans.
I didn't know you wanted a pre-built one. Didn't really state that too clearly in the beginning, that or I read things fucked up lol. In that case I'm not too sure if PTC sells already built transmissions..
TX
andy was a textbook tuner , he was not as good as everyone thinks. Travis is the man , my power curve was clean as hell when travis got done with it. i cant say enough about GH
CandyRedGT
Illinois
Brensped is an hour away and LIVERNOIS is about three hours.
Both companies excellent with great customer service.
I an going to talk with both of them about tuning the TWINS after i get the trans in.
Brenspeed is a GREAT palce to go!!!! Hopeing the TCI is ok this time around. NOT Brenspeeds fault. Superb shifting trans when it works right. Thinking as soon as they get the NEW design clutchs in it..it should be fine. The 3000 stall really launchs nice too!
US-1
Banned
The ShadowLands
Performance Automatic. Mine is essentially a Super Street 5R55S and it has done damn well since 2008 with the twins on the car during the 2008 FFW championship run and in street driving after that. I have a transmission tune from Doug at BamaChips so you're S.O.L. on that unless you can find the rabbit hole he fell into. JDM should be able to do an email transmission tune. Brenspeed should also be able to help in that department.
PM me for a price on a complete transmission. I'm a dealer.
TexasKyle
D.I.L.L.I.G.A.F
Katy, Tx
Oh hell, I forgot about that. Muhahahaha. We are going to be talking in the near future about that...
INTRUDER
pm sent to you
sent me an email ..I want to send you a build sheet tell me what you think?
Hawgman
THE fucking bad guy
Texas
Intruder - If you want all the back and forth about tuners and whether or not they still tune pulled out of your thread let me know.
INTRUDER
TWIN TURBO build sheet
Here is a partial list of what has been done to the TWIN TERROR.....
More to come. Tell me what you think comments welcomed. Thanks
[FONT=&quot]TWIN TERROR[/FONT]
2005 Mustang GTT
TWIN TURBO BUILD SHEET
MOTOR
2005 Ford 4.6Aluminum Block
[FONT=&quot]Livernois STAGE 3 heads [/FONT][FONT=&quot]5 axis CNC machined, valves, [/FONT]
[FONT=&quot] Intake flow rate 300 CFM - Exhaust flow rate 215 CFM
1mm oversize (35mm) intake - 1mm oversize (38.5mm) exhaust valves, [/FONT]
[FONT=&quot]Livernois VCT Lockouts[/FONT]
[FONT=&quot]Crower Cams stage 2 [/FONT]
[FONT=&quot]Felpro Head gaskets[/FONT]
[FONT=&quot]Ford V10 Flex plate[/FONT]
[FONT=&quot]04 Cobra Crank [/FONT]
[FONT=&quot]Manley Pro Series Rods w/ L19 bolts - 9.0 to 1 [/FONT]
[FONT=&quot]APR/SP2000 Head Studs[/FONT]
[FONT=&quot]APR Main Studs[/FONT]
[FONT=&quot]Steeda CMDP Deletes[/FONT]
[FONT=&quot]Main Bearings[/FONT]
[FONT=&quot]Rod Bearings[/FONT]
[FONT=&quot]New Lifters, Oil pump, rear main seal, [/FONT]
[FONT=&quot]New Ford Timing Chain, tentioners and guides[/FONT]
[FONT=&quot]Brisk -2 colder[/FONT][FONT=&quot]spark plugs[/FONT]
CUSTOM TURBO SET UP
[FONT=&quot]TURBOS - TWO (2) GTR3582R Garrett [/FONT]
[FONT=&quot]Headers-Stainless steel stepped 1-5/8” to 1-3/4” [/FONT]
[FONT=&quot]Header flange tapered ½’ thick[/FONT]
[FONT=&quot]Down pipes Custom Stainless steel 2-1’2”[/FONT]
[FONT=&quot]2- 38 mm Tial Waste gates[/FONT]
[FONT=&quot]1- Tail Blow off valve[/FONT]
[FONT=&quot]V-Clamps Stainless steel[/FONT]
[FONT=&quot]Hose Clamps Stainless Steel[/FONT]
[FONT=&quot]Silicon Hoses High Temp[/FONT]
[FONT=&quot]Custom Air to Air Inter-cooler custom made **flow rated @ 1300 cfm[/FONT]
[FONT=&quot] Inter-cooler Set up 3” & 4” tubing[/FONT]
FUEL SYSTEM Custom RETURN STYLE
[FONT=&quot]Fore Precision Triple Pump & Fuel blocks[/FONT]
[FONT=&quot]100micron fuel filter[/FONT]
[FONT=&quot]Walberg fuel pumps (3)[/FONT]
[FONT=&quot]Metco Fuel rail[/FONT]
[FONT=&quot]60# Ford Injectors[/FONT]
[FONT=&quot]Lines are ALL Aeroquip & braided steel [/FONT]
SPEED SERVICE
[FONT=&quot]Bore block 20 over with torque plate[/FONT]
[FONT=&quot]Install main studs and line hone with torque plates[/FONT]
[FONT=&quot]Surface block deck [/FONT]
[FONT=&quot]Cut 10/10 & polish cobra crank[/FONT]
SUSPENSION front
[FONT=&quot]BMR Tubular K-Member[/FONT]
[FONT=&quot]BMR Upper control arms[/FONT]
[FONT=&quot]Steeda Radiator Support[/FONT]
SUSPENSION rear
[FONT=&quot]Metco Drive shaft safety loop[/FONT]
[FONT=&quot]Heavy Duty Upper Control Arm Bracket[/FONT]
[FONT=&quot]Upper adjustable Control Arm[/FONT]
[FONT=&quot]Control arm relocation brackets[/FONT]
[FONT=&quot]Adjustable Lower Control arms[/FONT]
[FONT=&quot]Differential Bushing[/FONT]
[FONT=&quot]Adjustable pan hard bar[/FONT]
Coming soon… S&S Chassis Custom built 8.8 rear end
Shortened 1.5” per side, re-welded and gusseted
STRANGE c-clip eliminators Basically everything Strange has for a 8.8
New coil over
TRANSMISSION
TCI Super Street Fighter Transmission
TCI shifter
1pc aluminum driveshaft
[FONT=&quot]Custom Fab oil pan and oil pick up[/FONT]
[FONT=&quot]Windage tray[/FONT]
[FONT=&quot]TCI 3200 [/FONT]
[FONT=&quot]Remote trans oil cooler[/FONT]
EXTERIOR
[FONT=&quot]Steeda Side Window louvers[/FONT]
[FONT=&quot]CDC Hood Scoop with built in turn signals[/FONT]
[FONT=&quot]CDC Chin spoiler[/FONT]
[FONT=&quot]Sequential tail lights[/FONT]
[FONT=&quot]Rear gas cap and lock removed and smoothed[/FONT]
[FONT=&quot]Black Chrome mess grill upper and lower[/FONT]
[FONT=&quot]Hood Struts[/FONT]
[FONT=&quot]Clear front signals[/FONT]
[FONT=&quot]WHEELS & TIRES[/FONT]
[FONT=&quot]Godspeed 5" lip Black spoke with polished rim[/FONT]
[FONT=&quot]18x10 rear 18x9 front[/FONT]
[FONT=&quot]REAR tire
MICKEY THOMPSON 305/50/18 ET STREET RADIAL
Rear is lowered 1 inch[/FONT]
[FONT=&quot]FRONT tire
18x9 General Exclaim UHP 255/40ZR18
front stock ride height
[/FONT]
INTRUDER
Thank you... I just want to know "FROM EXPERIENCE" who has direct knowledge of 5R55s Aftermarket transmissions.
Q? Have you bought and run a "5R55s trans form anyone?
Q? What is your opinion of the trans you are running?
Examples;
"Peter Del Pino built my 5R and that sum'bitch was stronger than I could ever ask for" Antonio1988
Thanks everybody for your input ...BUT.... Examples above is what I'm looking for.
"I have lost 3 5R55S transmissions:
(1) due to the installer of the torque converter not having the adapter plate aligned properly and (2) as a direct result of a tuner that didn't know how to tune for the 5R55S." tmcolegr
"Stock 5R55S with SSF full upgrade kit from TCI. PA deep pan and PTC rebuilt stock TC/3600 stall. Held up for 2 years with zero problems!! JDM tuned!!" 07stangcs
